  1. steve todd
    steve todd Member
    Dec 15, 2017
    82
    10:20 PM
    how do Guys test for potassium as down. Here in oz I’m unable to buy a test kit for this
    Cheers
  2. Tom Barr
    18,693
    726
    12:20 PM
    Estimation based on tap water (they will let you know the K+ levels, folks with heart issues need to know etc) and dosing.
    They make turbidity test for K+. Not many use it. K+ can be over a wide range is rarely limiting if folks dose KNO3.....
    Some add K2SO4 on top of that just in case, I've never needed to after a decade now.
    Hanna and Hach both make test kits for it.
  3. steve todd
    steve todd Member
    Dec 15, 2017
    82
    10:20 PM
    Thanks Tom u was advised in a post to have mine at 5ppm. So Unless i have a kit I won’t know
    Cheers
  4. acinonyx
    acinonyx Member
    Aug 10, 2017
    24
    40
    1:20 PM
    As Tom said, JBL and others make tests for it. The test work all on the very same principle so it does not really matter that much which one you get, I guess.
    When testing, be careful with how you handle everything, because there is quite a bit of K+ on your hands (especially if they are a bit sweaty) usually which could skew the results.
