Just added CO2 how low should pH get?
Discussion in 'CO2 Enrichment' started by lipadj46, Apr 21, 2011.
  1. lipadj46
    lipadj46 Junior Poster
    Apr 6, 2011
    19
    7:10 PM
    So I just added CO2 and I have about 2 bps going now. I don't have a drop checker yet and won't until next week when I can get back in the lab and make one. My question is what is the lowest I should look for my pH to get, 6.0? I would rather not kill my daughter's fish!
  2. Jeremy1
    Jeremy1 Prolific Poster
    Aug 12, 2008
    64
    7:10 PM
    I would not go below 6. Adjust co2 slowly and monitor closley. As long as your fish are not gasping at surface your are good. Knowing the KH will give you an idea of your buffering capacity. KH of between 4-5 will protect you from lowering the PH too rapidly from CO2 injection.
  3. Cyclesafe
    Cyclesafe Guru Class Expert
    Jan 19, 2011
    136
    7:10 PM
    Be aware that with CO2 addition it is the change in pH at a given KH, not the absolute pH that is relevant here. A good rule of thumb is that a 1.0 decrease in pH equals (with lots of hand waving and caveats) 30 ppm of CO2. BPS is only marginally relevant in that your CO2 concentration is also a function of the volume of the tank, your CO2 injection method, as well as several other factors.
    When your fish start gasping it's often too late. Although CO2 stress is considered reversible, it's difficult to reduce the concentration in time. If you are concerned about your fish, I'd read the threads here on CO2 before you start using it.
    #3 Cyclesafe, Apr 21, 2011
