I pulled down my planted tank that I set up in 2007 recently and made it an easy care fish only tank, gave all my plants away (the tank had become almost impenetrable wall to wall C.balansae) in preperation for some extended travelling around Australia for my wife and I. Well circumstances have changed (we've become first time Grandparents) and it's now being set up again as a planted tank. So the Co2 has been dusted off etc and all re-connected. The only thing that I haven't re-installed this time is the Red Sea under substrate heating cable I don't think that the pay off for the cost of electricity running it actually was worth it.
Tank: 4x2x2 10mm standard glass, braced tank (I'd love an unbraced tank!).
Substrate: Plain inert gravel thats now over 4 years old and full of mulm, DIY iron rich clay balls and Seachem root tabs.
Fertilizer regime is EI -
4.5x teaspoons of KNO3
3x teaspoons of KH2PO4
Dissolved in 140mils of distilled water and dosed 20mils per day and 10mils per day of Seachem Flourish and either Seachem Iron or DIY iron mix 2x times per week and Seachem Trace mix 2x per week.
(I have a 13% Chelated Iron and SimpleGrow Trace Mix and also PMDD crystals)
I have very soft water so I do add Calcium Sulphate and Magnesium on water change times.
Also for the first time I have used Osmocote 'ice cubes'.
CO2 is administered via a Dupla regulator, Dupla Magnetic Solenoid, Dupla bubble counter, Dupla Reaktor 400, Dupla Drop Checker and a BOC 'D' size 6kg cylinder and a high bubble count.
Lighting: Aquamedic Aquaspacelight 2 x 150w 10,000k metal halide lighting unit. I made a timber shroud around the spacelight and it makes it much nicer cutting down any escaping glare.
Filtration: 4 x Eheim 2217 canister filters. One returning through a spray bar and the other through a curved return pipe.
Heater is a 300watt Eheim.
60% - 70% water changes 2x per week, in winter I heat the water in a barrel (4x 300w heaters and an Aquaclear powerhead) with some Prime added, in Summer it's straight out of the garden hose and Prime added to the tank.
Initial setup 26th July 2011 -
My plant list -
Bacopa sp Japan
Cardamine lyrata
Crypt "Undulatas"
Crypt wendtii "Brown"
Crypt Balansae
Limnophila aromatic
Heteranthera zosterifolia
Micranthemum umbrosum
Rotala rotundifolia
Ludwigia arcuata
Hygrophila polysperma "Sunset"
Hygrophila difformis
Ambulia aka Limnophila sessiliflora
Glossostigma elatinoides
Helanthium tenellum "Micro"
Lilaeopsis brasiliensis
Pogostemon helferi
Riccia fluitans
Staurogyne
Ranunculus inundates
Microsorum pteropus
Microsorum pteropus needle leaf
Echinodorus gracilis
Echinodorus quadricostatus
Echinodorus latifolius
Nymphaea lotus Red Tiger Lotus
Java Moss
I suppose I'm guilty of collectoritis.
My plant list -
Bacopa sp Japan
Cardamine lyrata
Crypt "Undulatas"
Crypt Balansae
Limnophila aromatic
Rotala rotundifolia
Ludwigia arcuata
Pogostemon helferi
Riccia fluitans
Staurogyne
Microsorum pteropus
Java Moss
