Iwagumi Setup - Only 6 Days to Submission and algae !
Kshitij
Mar 23, 2012
6
Dear,
This is kshitij Gupta from India.
I have been following you forum, and today i am happy to join it :)
I Recently started my New iwagumi layout with dry start method, formed a HC carpet and filled it with water. Its been around 15-20 days since the tank has been flooded. The tank was emersed for around 2 months.
The tank was doing well until last week i started seeing some signs of algae which i was able to control it, but problem arised when i Co2 cylinder exausted and there was fluction in Co2 for a day. The tank is not filled with hair algae and i have to submit this tank for ADA india competetion whose last date is 31st march - a week only !
Am very worried since i don't how how to solve this problem urgently and ready the tank for a good shot for the competetion.
Following are the tank photos to help you get the view :
Tank Specifications :
Tank size - 36 in x 15 in x 17 in
Substrate - ADA New Amazonia + Powersand Special
Light - 2.3 Watt/Gallon
Ferka dosing - Balanced k and Aquatilizer
Co2 - 3 bps Pressurized.
I am worried regarding the tank submission, need your idea and help to solve this problem.
Daily water changes, 60-70%, and add lots of Amano shrimp, clean your diffuser, add a little more CO2, this is a CO2 issue, algae like this does not bloom on it's own suddenly like this unless neglect is done on some level.
The HC does not form a nice tight carpet, that's one clue it's CO2.
Kshitij
Mar 23, 2012
6
Dear,
I am facing very bad issues, amano shrimps are not available now therefore i have put in some low grade RCS yesterday. I have increased co2 to 4bps like you said. I am facing water shortage to my area from past 15 days therefore WC can be done 30% max everyday only.
Can i inject h2o2 directly on hair algae ? because i have to take a photo after 4 days only ?
Heave trimming is done just a hour back, trimmed completely vivipara, and trimmed HC and manully removed hair algae with toothbrush as much i could, but still it is completely entangled with HC at many places.
Need some serious advice on this as i am getting confused completely :(:confused:
Well, if you cannot get shrimp or do decent water changes, there's not a lot of hope frankly.
Stick 30% as long as you can.
But daily, do them maybe 30-60min after the lights come on.
Matt F.
2,319
California
I'm not the Tom-man, but I agree with his advice. I've been through this, too.
I know from personal experience that what Tom says is sound advice. Make sure to soak you diffuser in bleach at least once a week. I sometimes soak my diffuser 2x per week to keep the CO2 flowing freely.
Increase that CO2! Crank it!
You might also want to do a 3-4 day black/brown out. Do not turn your lights on for 3 days (72 hours). This coupled with a large >50% water change, a clean diffuser with an increase in CO2, and some patience should get you back to where you want to be.
Also reduce your photoperiod to 5-6 hours per (after the 3 days brownout). Then increase your photoperiod 1 hour per week till you reach 8-10 hours. If algae starts again, go back down to a 6 hour photoperiod.
Red Cherry Shrimp should be fine for algae. Just add as many as you can. It will take quite a few to make a dent in the algae.
Also, do you have access to glutaraldehyde or Seachem Excel? This might help, too. Just make sure the glutaraldehyde is the right concentration.
Matt F.
2,319
California
Some inspiriation for you...
This is how much I inject in my 60P (68 Ltrs.?)
I keep my diffuser bright white.
Kshitij
Mar 23, 2012
6
@ Tom Barr :
Thanks for the information.
I was out for some time to the tank was even more neglected, i did whatever i could do till i was here but its full of algae now.
I have removed algae with the help of toothbrush as much as i could but its taking over very fast, now there is BBA also. I have called in amano and will arrive in 2 days time. I will start water changer from tomorrow morning itself @50% everyday just like you mentioned after the light has been turned on for half to one hour.
The diffuser is cleaned :)
@Matt F. :
Thanks a lot for the motivation :) yeah looking at the pictures i have decided to make it a routine. - once a week. I will post some pictures soon.
Now here is what i have decided for the tank :
1. Water change from tomorrow 50% for a week.
2. Co2 cranked - 4 BPS.
3. Will introduce amano shrimps and SAE in 2 days.
4. Manual cleaning.
Following is further information about the tank :
1. The light is switched on for about 8-10 hours a day - Time- 9 am to 5pm/7pm.
2. Co2 is always on @4 bps.
3. One of the lights in that tank is flickering - is going on and off atleast 15 times a day. so will change it.
3. Another issue is that i have this tank in my room now, the morning temperature is 26-28 but at night after 10 till morning that AC is on and the temperature goes down, does this become an issue ? because Co2 is also always on and colder water has more dissolved co2.
4. Dosing is Ferka Aquatilizer (Micro) and Balanced K. I am not dosing any N, i feel there is enough in ADA the new amazonia.
I am planning the following, kindly guide me if i am wrong :
1. Plug in two timers - one for the co2 to turn on an hour before lights are on and other for the lights to switch off within the time frame of 5 hours for 1st week then increasing by an hour every week till it reached 8 hours per day.
2. I need suggestion on plants, do i need any competing plants ? like HC cuba or should i remove vivipara and put ricca behind to balance the plants ?
3. Or last thing do a blackout for 3 days and then follow the above routine ?
