Issue With E.Stellata; curling leaves?
Martin
149
44
Sebbersund, Denmark
Hi..
in a new setup my E.Stellata seems to be suffering somewhat. The leaves curl, which they didn't before, in my old tank.... I moved to a different town, and waterparams. are different. Also i have more light now.
Setup is:
85G
2x125W HQL
Co2 is about 48ppm
pH is 6.8 with Co2 addition.
kH is 10-11
gH around 11
M 3/4 kno3, 20ml Trace, 5ml Iron
T 1/8 KH2PO4 1/4 K2So4
W 3/4 kno3, 20ml Trace
T 1/8 KH2PO4
F 3/4 kno3, 20ml Trace, 5ml Iron
S 1/8 KH2PO4 1/4 K2So4
S Waterchange 50%
PeterGwee
126
Re: Issue With E.Stellata; curling leaves?
Seem like a CO2 issue to me. Add more as long as the critters/fish are fine. Watch closely though when you do it and make sure you have moderate surface movement. What type of trace mix are you using?
Regards
Peter Gwee
Martin
149
44
Sebbersund, Denmark
Regards
Peter Gwee
I use CSM+B from Greg Watson
PeterGwee
126
Try cranking the CO2 then...I doubt trace mix has such big impact. You can always switch to commercial trace mix from Tropica or Flourish (not the trace but regular flourish). Give the plant some time to bounce back though.
Regards
Peter Gwee
775
Agreed, this plants gets squirrlely at low CO2 and that looks like it.
Good nutrient dosing and pruning, upkeep etc, then adjust the CO2.
DavidR
Apr 1, 2005
Texas
Yep, CO2. With your KH, try a 6.4 pH. Don't worry 'bout that little CO2 chart. My KH is 12, and I find that a 6.2 pH works nicely.
