Is Wet's calculator for drop checkers right?
Discussion in 'CO2 Enrichment' started by fablau, Jun 29, 2014.
  1. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,911
    626
    4:13 AM
    Hello everyone,
    Today I wanted to play a little bit with drop checkers, so I went online on wet's calculator below:
    http://dropcheck.petalphile.com
    What I'd like to have is a drop checker that turns yellow when my co2 reaches 40ppm. I think yellow is easier to see than green, at least for me, so I wanted to check that option.
    So, here is what I have done:
    1. Entered 40 as target co2 ppm.
    2. Left margin of error of +-5.
    3. I chose to mix in 1 liter DI water.
    4. I checked the yellow option.
    5. I checked one drop checker.
    So, with the above input, wet's calculator tells me to add 159.2 mg of baking soda do 1 liter of DI water to have a solution of 5.31 KH. Then add that solution to my drop checker, add 2 drops of Bromithymol, and the checker should turn yellow when Co2 concentration reach around 40ppm.
    Ok, now get back to the calculator form again, and change the color option from "yellow" to "green"... Well, you would expect different instructions, instead you still get the exact same dose (159.2 mg of baking soda per 1 liter of DI water to have a solution of 5.31 dKh). Why's that??
    Also, try the "two dropcheckers" option, with the "yellow" option checked, and you'll get a completely different recipe for the first drop checker which should target 45ppm of co2: 45 mg of baking soda per 1 liter of DI water to reach a solution of 1.50 dKH.
    Now, get back to the calculator form, then enter 45 ppm as target, leave the rest as it is, and check "one drop checker".... Well, you'll get a different result than the suggested dosing for the first drop checker with the "two dropcheckers" option just tried above:
    179.1 mg of baking soda for 1 liter of DI water, to reach a dKh of 5.97.
    Well, I can't understand the sense of a such mismatch between results. Can you?
  2. Wet
    Wet Lifetime Members
    Aug 25, 2006
    395
    12:13 PM
    Hi fablau,
    Wow, yeah I can see how that is all so confusing. I hadn't looked at this calculator for a long time and the code is really confusing too. Hearing you're using it makes me want to rewrite the instructions and the calculator so maybe we can keep adding to it!
    The first problem that probably causes confusion is the margin of error input only works with two drop checkers and has no effect on one drop checker's calculations (this is because we use the margin of error in color between multiple drop checkers). I added a note about that but need to spend some time redoing some stuff to make it cleaner looking (I hope! :) )
    "So, with the above input, wet's calculator tells me to add 159.2 mg of baking soda do 1 liter of DI water to have a solution of 5.31 KH. Then add that solution to my drop checker, add 2 drops of Bromithymol, and the checker should turn yellow when Co2 concentration reach around 40ppm.
    Ok, now get back to the calculator form again, and change the color option from "yellow" to "green"... Well, you would expect different instructions, instead you still get the exact same dose (159.2 mg of baking soda per 1 liter of DI water to have a solution of 5.31 dKh). Why's that??"
    This is actually correct. It's because if you calibrate for "green," the center of that range in the drop checker will be the same as if you calibrate for "yellow."
    An example may explain this better. Let's say we're using the 30ppm/4dKH standard most folks use with dropcheckers.
    If I calibrate for green, "green" will be 30ppm. If my drop checker turns yellow, I have more than 30ppm. If it turns blue, I have less than 30ppm.
    If I calibrate for yellow being 30ppm, it's exactly starting at the same place as if I calibrated for green. It's just that I pick yellow for that state at 4dKH instead of green. So, if the drop checker now turns green to my eyes, I have less than 30ppm CO2. If it turns a pale yellow/etc, I have more than 30ppm CO2.
    Another example because even as I type that it's confusing.
    Let's say I draw a line across a see-saw that is perfectly level and I intend to balance an object on that line. The object will roll to the left if the see-saw lowers on the left. It will roll to the right if the see-saw lowers on the right.
    It does not matter where I draw the line if I know it is level. I could even draw the object all the way at the left or right edge and it will still work.
    It's the same idea with starting at yellow or green. The drop checker is the same if you pick between green or yellow for a given CO2 (with one drop checker). The formula for dKH will only change if you change the target CO2 for that starting state, be it yellow or green.
    Please let me know if that is all badly explained and still confusing!
    "Also, try the "two dropcheckers" option, with the "yellow" option checked, and you'll get a completely different recipe for the first drop checker which should target 45ppm of co2: 45 mg of baking soda per 1 liter of DI water to reach a solution of 1.50 dKH."
    This will be even trickier to explain!
    If we use the pH chart that comes with most AP tests, green can be anywhere from pH 6.4 to 6.8. Yellow is just 6.0 on that chart.
    So in that calculation, that value you're sharing is just for the first drop checker. You'll make an entirely different mix for the second drop checker.
    Now, the idea is if both drop checkers (with different dKHs and therefore different pH and CO2 ranges for a given color) agree -- that is they are the *same* color -- you can have a reasonably high degree of confidence that your tank really is at the CO2 ppm. The margin of error lets you adjust that range but always acknowledges there is some margin of error. (Say +/- 5ppm.)
    In other words, you add drop checkers so that you can be more precise, assuming both drop checkers are calibrated correctly. This is a big advantage vs one drop checker, especially if you think the colors to the eye aren't as precise as the pH chart. (This is also why the calculator prints a pH chart -- it helped me visualize it but I can see how it only adds to the confusion!)
    "Now, get back to the calculator form, then enter 45 ppm as target, leave the rest as it is, and check "one drop checker".... Well, you'll get a different result than the suggested dosing for the first drop checker with the "two dropcheckers" option just tried above:"
    Yeah, I think this confusion is from the margin of error. The reason that 45ppm +/- 5ppm is so different than 40ppm +/- 5ppm is the +/- part doesn't count on single drop checkers. :) I hope the new line there helps that.
    Does this help? Sorry it's such a weird tool to use without knowing these things. I'll try to cleanup the "How it works" section when I redo it!
  3. fablau
    Sep 13, 2008
    2,911
    626
    4:13 AM
    Thank you so much Wet! Your first explanation about my green/yellow question was pretty easy to understand (thanks!), the other two required a re-reading of 2-3 times from my part, but at the end I think I got it, and they look more complicated of what they are, really. I think that what you have eloquently explained, at the end is simple to understand!
    The problem is that numbers sometimes are confusing. :)
    I really appreciated your help, and I will proceed to create the two different solutions suggested to use two drop checkers.
    Thank you again!
  4. Tom Barr
    18,694
    731
    12:13 PM
    What might be a better solution is making a Drop checker with a 1/2" rubber gasket for a pH probe to enter the solution inside.
    This would give a far better accurate measure of the pH.
    No solution other than KH reference would be needed. There's still a delay time of roughly 2 hours or so.
  5. Wet
    Aug 25, 2006
    395
    12:13 PM
    NP fablau, glad to help :)
    Tom - yeah that's super cool. Since at that point it's a data stream off the pH probe, it could be really cool to push the data to charts and stuff using the new wave of
  6. fablau
    Sep 13, 2008
    2,911
    626
    4:13 AM
    Wet, there is a problem though: I have made the two solutions for two drop checkers as defined above targeting 45 and 35ppm respectively, but as I expected (unfortunately) with the fact such solutions are made with very low KH as suggested by the calculator (1.5 and 1.17 KH respectively, compared instead to the suggested KH of 5.31 for the single drop checker targeting 40ppm), those drop checkers are always yellow in my tank, even when my co2 is off and the tank is completely degassed. The single drop checker with the solution of 5.31 KH instead seems to work as expected: blue when degassed, yellow when I have saturated Co2 to reach my usual PH drop of 1.4-1.5.
    I had doubts on all this, as explained above, and by making the actual suggested solutions for two drop checkers, I see they not working as they should, and therefore, I see by doubts reinforced!
    Thoughts?
  7. Wet
    Aug 25, 2006
    395
    12:13 PM
    Wow, yeah. There has to be a bug here vs the single drop checker calculation and sorry I missed that. I will review the code in a few days (away from this project for a bit) and will update. I do not think those calculations are correct.
    Also, if ou get around to it ou'll find very low KH outputs a warning and a quote from Hoppy and myself about that situation. But I *think* that shouldn't be a problem here, just that the outputted KH is too low than what you need. I *think* you can reach those two targets with two drop checkers once the calculation is fixed. But it's been a while so I may be wrong.
    Will update!
  8. fablau
    Sep 13, 2008
    2,911
    626
    4:13 AM
    Thank you wet, glad that makes sense to you!
    I appreciated your quick reply, and then I will wait for your update.
    But I the meantime, shouldn't be ok for me to make two different solutions (one for each drop checker) by simply using the calculator to make the solution for the single drop checker, by targeting 35ppm and 45ppm for each drop checker? That way I should get the correct KH (4.64 for 35ppm and 5.97 for 45ppm). Wouldn't that work in the same way with 2 dropcheckers?
    Thanks!
  9. Wet
    Aug 25, 2006
    395
    12:13 PM
    Thanks for understanding fablau!
    Yeah, that sounds and looks right to me based on the single drop checker outputs. Sorry it holds up your experiment though and interested in how that works out for you.
    - - - Updated - - -
  10. fablau
    Sep 13, 2008
    2,911
    626
    4:13 AM
    Great! I will try that then. Thank you!
  11. glad
    glad Junior Poster
    Apr 18, 2015
    12:13 PM
    Sorry for posting in a old thread! The calculator seems to be offline or is it being updated perhaps?
  12. Jason King
    Jason King barrreport.com
    Nov 20, 2011
    1,575
    381
    12:13 PM
    Just checked its online :)
  13. glad
    glad Junior Poster
    Apr 18, 2015
    12:13 PM
  14. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    12:13 PM
    It's off-line for some reason. Wet's Nutrient Calculator is working, however.
    Also, I've checked the weights of my fertz using a gram scale. Some fertz are under-estimated (like, CaSO4, K2SO4 and KNO3) but it's also possible that the fertz have absorbed atmospheric water and is thus heavier. Some are lighter (KH2PO4) though that's probably because it's a coarser grain size than was used for the calculator.
