Hi all,
I know, this stuff is laid out to be easy, no need to calculate, etc...
That's all good, and I'm using it, but I'm never one to let that sort of thing be, so I just had to figure the math behind it all. I always want to know the how and why of things, and to verify what others say. This post is more for a sanity check, and to make sure I'm not way off base.
First some assumptions (and I apologize for the MATH, but I just HAVE to know...
): KNO3 weighs 5.6 grams per tsp and contains 68.328% NO3 and 38.672% K, and KH2PO4 weighs 4.8 grams per tsp and contains 28.731% K and 69.788% PO4. I arrived at these numbers from various sources, including Chuck's Planted Aquarium Calculator, and sites such as http://www.convertunits.com/molarmass/KNO3. I'm also assuming each aquarium contains 85% of it's capacity in water, due to substrate, etc. So a 29 gal tank has 93.3 liters and a 20 gal tank has 64.4 liters.
I prefer to dose daily (easier for me to remember) using a liquid solution. I mix up my solution with 450ml of water. Into the water I mix 5 tsp (28 grams) of KNO3 and 1/2 tsp (2.4 grams) of KH2PO4. The resulting solution contains 35,745 ppm of NO3, 22,540 ppm of K and 3,486 ppm of PO4. With me so far?
Now, I chose these amounts so that I could dose both my 20 gal and my 29 gal using the same mixture, and simply dose a diff amount into each tank. The 20 gal receives 6 ml of this solution daily, and the 29 gal receives 9 ml daily. And I do 50% water change weekly.
I figure I am dosing the following weekly, and this is the part I want confirmed:
29 gal: 9 ml solution daily provides 24.1 ppm NO3, 15.2 ppm K and 2.4 PPM PO4 weekly.
20 gal: 6 ml solution daily provides 18.9 ppm NO3, 11.9 ppm K and 1.2 PPM PO4 weekly.
Are my calcs accurate? Is this an appropriate amount to dose (meaning, is it way too much or to little)?
(BTW, I also dose micros, but I'm leaving that out of this conversation for the moment).
Once I'm comfortable that this is correct, I'll file away the calculations and forget about them, and simply remember how much of what to add and dose.
Any thoughts?
Thanks,
Tim
Any thoughts?
Thanks,
Tim
