Is It Better Not To Have A Ph Controller Hooked C02 System
Discussion in 'CO2 Enrichment' started by #1 Plant Boy, Sep 5, 2018.
  1. #1 Plant Boy
    #1 Plant Boy New Member
    Aug 22, 2018
    12
    2:34 AM
    Currently I iam using a ph controller to control the c02 output in my aquarium. My plants are suffering bad and was wanting to know if plants would be better off by not controlling the c02 output during the day and Instead giving the plants a constant supply of c02.
  2. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,298
    4:34 AM
    If you have an inert substrate like gravel or sand, they can be useful as long as you keep the probe calibrated.
    They are not good to use with aquasoil or any substrate that changes the KH, because co2 will not be consistent as the KH rises and falls if you keep the same PH
    Aaron Chen likes this.
  3. tiger15
    tiger15 Member
    Aug 12, 2017
    238
    81
    5:34 AM
    I have never used pH controller but own a pH pen. I notice that if my CO2 injection generates a substantial amount of CO2 mist, the pH pen will underestimate the ppm of CO2 based on pH kH chart. Like pH pen, pH controller measures H+, not CO2 mist which is free gas, but both are available to plants.
  4. #1 Plant Boy
    Aug 22, 2018
    12
    2:34 AM
    I am using turface' pro league for my substrate. Is that a substrate that shouldn't be used with a ph controller?
  5. burr740
    Feb 16, 2015
    1,398
    1,298
    4:34 AM
    Im not sure but just from looking it doesnt seem to have any buffering capacity, just a high cec. Think it would be OK
    However, running co2 24/7 almost certainly wont make any difference to your struggling plants. They are struggling for some other reason.
    You should start by making sure CO2 during the day is good - have an adequate concentration by the time lights come on and running the same rate every day
  6. Greggz
    Greggz Lifetime Members
    Jan 6, 2016
    448
    577
    10:34 AM
    Agreed.
    If you really want help, post as much information as possible about your tank and set up (size, lighting, ferts, plants, etc. etc.), along with pictures. Many would be happy to offer their thoughts.
    I use a CO2 controller, but really it's just a convenience. And IMO, having one or not having one has nothing to do with your plants being unhappy.
  7. #1 Plant Boy
    Aug 22, 2018
    12
    2:34 AM
    OK thanks. I did post in the general plant topic section on this wesbite every detail about my setup and what I am doing and pictures of the condition of the plants.
  8. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    10:34 AM
    Use a calibrated PH controller to monitor PH to figure out your injection rate needed. Once you have done that you should just be relying on the static injection rate and use ph controller to just monitor now and then.
    Not sure what diffusion method is. If your diffusion method includes pushing gas thru a ceramic media, it can get clogged so in that case a constantly calibrated PH controller can be helpful because you can keep increasing your injection to compensate for clogged diffuser and not worry about gassing your fish.
Tags:
