Is a UV Sterilizer Worth Getting?
Discussion in 'General Plant Topics' started by thegasman, Feb 3, 2013.
  1. thegasman
    thegasman Subscriber
    Aug 25, 2012
    252
    4:48 PM
    I'm thinking about adding a UV sterilizer to my upcoming switch to a sump based filter system. Is a UV sterilizer worth adding? My tank is doing great without one. I understand what they are and what they do, but don't understand if they are worth the expense. Are they just insurance for the "what if" scenario? What are the recommended brands that are good quality? Is it worth it to get one with the built in wiper?
    I will most likely get one, but am just wondering if I'll see any real benefit.
    I'm leaning towards the Aqua Ultraviolet Classic 15 watt for my 34 gallon tank. It looks like it can handle a higher flow rate than others and still be effective.
    Any feedback would be appreciated.
    Thanks.
  2. puopg
    puopg Guru Class Expert
    Nov 19, 2012
    214
    4:48 PM
    I think they are definitely a nice thing to have as a back up incase of green water or killing waterborne algae. That being said, if you got your tank under control, seems like you don't need to run it.
  3. rogerfans
    rogerfans Prolific Poster
    Jul 5, 2010
    44
    4:48 PM
    UV is useful, but it isn't MUST. I met the green water, and purchased a UV sterilizer at $35. Green water was sloved by UV, but I never ever use it again.:gw
  4. scottward
    scottward Guru Class Expert
    Oct 26, 2007
    958
    10
    4:48 PM
    I've just purchased a TMV Vecton 600 for my 100g tank. Started hooking it up last night, hoping to finish it tonight. I'm running it immediately after one of my Eheim 2217's.
    The reason I bought one is for the fish. I often have problems with bacterial diseases affecting my fish, even simple live bearers don't last before they succumb to something. Coupled with the water changes I do, I'm hoping I can create a more healthy environment for the fish, eventually I'd like to get some discus.
    There are other benefits to using one that are a bonus, such as helping somewhat towards algae control and general water quality.
    I'm going to run mine 24/7 initially.
    From the research I've done whether you could find one useful or not depends. If you are having no problems with disease or green water etc, I guess not.
  5. captnphil
    captnphil Junior Poster
    Sep 23, 2012
    14
    4:48 PM
    Dont forget its all about flow vs watts!
    More flow, less "cleaning"
  6. HisXlency
    HisXlency Junior Poster
    Feb 13, 2013
    21
    4:48 PM
    Good info as I want to add one to my modest setup as well. Any suggestions for a 20L with an eHeim 2217?
  7. scottward
    Oct 26, 2007
    958
    10
    4:48 PM
    One of the smaller Vectons would work fine - just check the flow rate - you'll probably be pumping out 600lph like me.
