From JeffyFunk's water testing results (using a proper machine) we figured out that only EDTA and DTPA chelated iron show up in water samples. Gluconate and citrate chelated iron does not show up at all in his tests. I suspect the same is true for the titration kits you can buy.
Petex;123575 said:Thank you very much if you would ask on a place where ppl. know such things.
The Test kit i have uses a mix off acetic acid + sodium hydroxide to change the PH from the test solution, so that the iron gets unbound from the chelate - but it hasn´t worked out. Like you can see on this chart, Fe-EDDHA is pretty PH stable and so I guess many test kits may have some serious problems with such strong chelates: http://www.smart-fertilizer.com/loadedFiles/iron chelate.png
Petex;123639 said:The KH isn´t high, but I need to pump lots of ferrous gluconate iron in my highlight tanks, let say 0,3-0,5ppm/day and doing so will be expensive in the long run.
50-100g Ferrous gluconate cost in Germany around $60-80 and this seems not to be the best price deal if 100g Fe-EDDHA, Fe-DTPA and similar stuff, cost less then $10.
