Introduction Of My Aquarium
Discussion in 'Introductions' started by Jaap, Jul 15, 2018.
  1. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    Size is 130x55x70 500 litres
    #1 Jaap, Jul 15, 2018
    LRJ, Jason King, burr740 and 2 others like this.
  2. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    Some additional pictures.
    toads74, LRJ, Jason King and 2 others like this.
  3. LRJ
    LRJ Subscriber
    Aug 11, 2014
    102
    54
    7:58 PM
    Beautiful tank!
  4. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,300
    6:58 PM
  5. Greggz
    Greggz Lifetime Members
    Jan 6, 2016
    448
    578
    12:58 AM
    Looking good. Nicely presented.
    You should include some details on the tank, as I am sure many here would be interested.
  6. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    What are the details you are looking for ? I can talk for hours about this thing.
    burr740 likes this.
  7. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
  8. Greggz
    Jan 6, 2016
    448
    578
    12:58 AM
    The usual..................substrate, lighting, ferts, CO2, maintenance, etc........
    Phishless likes this.
  9. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    Substrate is pool filter sand grain size 0.7 to 1.25 mm. No additives, just an 8 cm thick layer of sand (4 cm at the front)
    The lighting is 5 bars of DayTime Matrix LED lamps. These bars can be fitted with LED modules of 10 Watts each. The LEDs used in these modules have 180 lm/Watt which is about twice the light output per Watt compared to a HO T5 lamp. Alltogether I have 25 of those modules in warm white, natural white and cool white. Cool in the front of the tank, natural in the middle, and warm in the back. Never did any PAR measurements because I am convinced there is more than enough. Lights are controlled with a TC420 dimmer, and are at 100% for 10 minutes each hour, and at only 20% in between. After 18:00 (when I am at home) the lights are on at 40% until 23:00 at which point they start to dim back to 0%.
    Filtering is done with an eheim canister filter. This filter also drives the CO2 diffuser and an UV lamp (which is never on) and because of that the flow from the filter is insufficient. Additional flow comes from a Sicce Voyager #3 stream pump (4500 litre/hour) which is very quiet but maybe a bit overkill.
    Maintenance is done each sunday afternoon and I try to stick to that. I do waterchanges of app. 75% and refill with 50/50 tapwater and RO water. The water in the aquarium is usually about 400 uS after I refilled it. Then I add ferts. Everything in one go, daily dosing is just too much trouble. I always add the same combination of ferts and I never do any testing (other than pH and conductivity)
    I also occasionally stick a GrowCaps capsule between the roots of plants that I think can use a boost. Growcap is a slow-release fertiliser, it's a mix of coated and uncoated stuff, this way there is an initial dose followed by the slower long-term dose.
    Fishload is: 50 Paracheirodon simulans, 25 Hyphessobrycon sweglesi, 8 Procatopus similis, 14 Otocinclus macrospilus (i think...) and 16 Amano shrimp.
    Greggz, sarpijk and LRJ like this.
  10. Wobblebonk
    Wobblebonk Member
    Jul 3, 2018
    23
    7:58 PM
    Is that a perfect "white" ring around that one tetra in the first pic or did you get it fitted for a rubberband somehow?!
  11. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    :D . A fish photobombed by an oxygen bubble.
  12. sarpijk
    sarpijk New Member
    May 6, 2018
    6:58 PM
    Hi ,great tank, I cannot see the additional pictures, I am on mobile (Tapatalk).
    How do you take care of Myriophylum Mattogrosense? Doesn't it grow too fast?
    I am also interested in your ferts dosing. Do you dose E.I quantities in one go?
  13. Jaap
    Jaap Member
    Jun 20, 2018
    33
    1:58 AM
    It is not M. mattogrossense and also not M. tuberculatum (in the trade these two are frequently mixed up) but it is Myriophyllum 'from roraima' . Not sure what species it is but some say it is aquatica. It is not available commercially, probably because aquatica is banned in europe due to its invasive properties. It grows very fast but you can always take everything out, cut off the nice top ends and then replant these. It has no problems with that and quickly builds a new set of roots.
    I dose nowhere near IE quantities, and everything goes in together once a week. LMD (lazy man's dosing)
    #13 Jaap, Jul 18, 2018
    snarkingturtle and Allwissend like this.
