Hi All,
I'm very new to planted tanks. I've been reading through most of the threads and I can say this is the best forum I've been to. All posts are valid and to the point. Everyone is so sincere about helping one another. It's a pity that I found this site so late.
Anyway, hopefully my questions have not been asked before. But in the event that they have been, please be patient with me as I'm still learning. Also, I'm from Singapore so if there's any term that's used wrongly, please correct me
Tank specifications :
36" x 18" x 18"
Currently approx 3/4 filled, containing 30 gallons or 115 litres of water.
Water specifications :
Water temp - 24 degrees Celcius
KH - 2 degrees
GH - 1 degree
pH - 6.5
No3 - 12.5 ppm
Po4 - 0.1 ppm
CO2 - 25-30ppm
Lighting :
T5 - 2 x 39W from 8.15am to 6.45pm (10.5hrs)
Can be increased to 4 x 39W if required.
Inhabitants :
4 otocinclus
approx 40 crystal red shrimps
7 bumblebee horned snails
Fertilizers :
Flourish Iron
Seachem Phosphorus
Seachem Nitrogen
Flourish Potassium
Flourish Trace
Been looking through the EI and I've tried it. I know I've got it all wrong on the first try as I've been hit by BBA / Green spot algae. My first mistake was adding all the ferts on the first day with 4 x 39W T5 shining into the tank. I came home to a large patch of BBA
Re-reading the EI thread, I realised ferts should be added based on tank requirement divided by no of doses per week. I've tried that too and still I see new patches of algae growing daily.
1. Noticed that dry ferts are used in EI. Is there a difference if I'm using liquid ferts? I'm unable to obtain dry ferts from the LFS.
I did some calculations on my own based on EI's target nutrients.
Potassium - 20ppm
Iron - 0.3ppm
No3 - 20ppm
Phospate - 1.0ppm
My dosing per week as follows :
28.4ml of Flourish Potassium
9ml of Flourish Iron
15ml of Seachem Nitrogen
14.4ml of Seachem Phosphorus
Thread algae / green spot algae are still found daily after weeks of manual removal. BBA was diligently removed upon sight
2. Is my dosing regime correct?
I strongly believe (influenced by Tom's multiple reminders in multiple threads) algae is caused by problems in CO2 or lighting.
Drop checker shows light green in the morning and dark green at night (when CO2 is switched off).
Attached is a picture of my tank, all comments are welcome. It looks clean as I've just done a major clean up / replanting before the photo.
Thanks for bearing with me and reading through the long post. Please let me know if I've missed out anything.
Thanks once again and cheers to happy plants ~~
Ryan
P.S. : I've halted my dosing regime after the major cleanup in case I'm doing something wrong.
P.P.S : Anyone able to identify the plants with red leaves? My LFS calls it the red leafed plant.
36" x 18" x 18"
KH - 2 degrees
GH - 1 degree
pH - 6.5
No3 - 12.5 ppm
Po4 - 0.1 ppm
CO2 - 25-30ppm
Lighting :
Inhabitants :
4 otocinclus
Fertilizers :
Flourish Iron
Seachem Phosphorus
Seachem Nitrogen
Flourish Potassium
Flourish Trace
Potassium - 20ppm
Iron - 0.3ppm
No3 - 20ppm
Phospate - 1.0ppm
Ryan
