And you'd be correct, it takes energy to break the organic bond, but this happens naturally via bacteria and fungi..............so in l,ow nutrient situations, this process is critical, if you have plenty of NO3 inorganic floating around.....then probably not.
The other issue, and one that's more critical is amnio acids, which are organic forms of reduced N.
These are what the plant makes from NH4 and NO3, so they require less energy to make into plant parts.
It depends on the system and it depends on what type of organic nitrogen is being discussed.
If thuis scertain person is convinced, they need to explain why they are so sure that aquatic plants cannot use it and state why, test, evidence, research background specific to aquatic plants or at least field crops.
Mere belief and speculation is hardly a standard to debate.
Another more basal question is: are there any real organic NO3 compounds such as nitrate esters and alcohols in your tank to begin with?
If not, this entire topic of debate is mute!
We have mainly organic reduced, not oxidized organic forms of N in our tanks.
So it's much more the R-NH2 groups that are really the issue.
The others are fairly rare in plants and tissues.
So...........we have amino acids, reduced organic N and NH4/NO3.
Without using a tracer, it's rather tough to say whether a plant uses or prefers anything, we might guess, but that's about it without actually testing it.
Testing and seeing if their hypothesis are true are not strong points for most aquarists. Seeing correlation and trying to tie that to cause and their belief is very much a factor however.
