Inducing Algae Growth
Emc2
I'd like to give this a try.
I have two tanks.
One 55 gallon, high-tech tank with 260 watts of lighting and pressurized co2 and one 26 gallon tank with no co2 and about 2 watts per gallon.
I am following EI on both tanks.
Which algae would be the easiest to start out with?
Watcher
Apr 16, 2005
23
50
College Station, Tx
Re: Inducing Algae Growth
From what I read on the EI method(I've only read it about 10 times), is that it prevents algae. Not induce it.
So maybe if you don't follow the EI method, it would be easier to induce algae.
787
I have two tanks.
Do you own a UV?
If so, use NH4 to induce green water.
Add lots of cheapy fish, shrimp etc to a planted tank to over load the system with organic NH4 waste.
Parameters to measure:
NH4 with a very sensitive kit many times in the first 6 hours and then every 6 8-12 hours thereafter till gone.
O2, meter is the best thing, they cost 220$+.
GW is easy to get rid of, a flip of the UV light and it's done in a few hours.
BGA is another, easy to kill, fairly easy to induce by lowering the NO3 with a fair amount of organic matter(clogged filter or over grown tank=> leads to more NO3 being used up=> more plant biomass).
BBA is problematic, hard to remove.
GS is fairly easy by limiting PO4. Few other algae will grow then.
Staghorn often appears with too many fish as well as BBA.
Rider
May 15, 2005
Tom Barr said:
(snip)
(snip)
Please tell us newbies what these abbreviations are. Even better, direct us to photos.
Laith
182
Geneva, Switzerland
BBA = Black Brush Algae
GW = Green Water Algae
GS = Green Spot Algae
PO4 = Phosphate
UV = Ultra-violet
NH4 = Ammonia
O2 = Oxygen
NO3 = Nitrate
Emc2
Since I don't own a UV I think I will start by trying to grow BGA. If that is sucessful I will set up a five gallon tank to induce the GW. That way I can just dump it out and not worry about buying a uv. Can I induce it without putting fish through the stress? Maybe do a fishless cycle?
reiverix
270
How do you grow the fluffy green stuff that looks kinda like moss? Beard algae and hair algae is what I want. I'm planning on turning a 10 gallon into a bright green algae fest for shrimp and loaches.
I'd love to do an algae scape.
Who woulda thunk people would be asking how to grow algae.
787
For BGA, don't clean filters, do not add any NO3 sources, adding soil can help(but you do not want Green water).
You can use eI, but delete the one element, say PO4 for GS, or CO2 for BBA, etc...........this assumes you have a sample of BBA etc to add to start things, BGa will not need this though(air borne)
Milan
Sep 28, 2005
34
62
Calgary, Alberta
I would be interested in knowing how to induce Diatoms in a FW tank. I had them before, and during that time my Otos were the happiest campers ever (poo-poo here, and a poo-poo there ... :) ).
I want them back ...! Tom, please help ...!
787
New tanks will get a temporany bloom. Generally they do well in lower light as a main bloom or in very nasty filmentous mat forming in waste water streams.
Those are not the diatoms you are after!
The low light ones are.
srozell
110
I've been growing algae deliberately for a while now, and find it quite intriquing. I find that hair algae is easy to get if you leave rotting leaves or other decaying matter in a quiet part of the tank. Once you get it started it's easy to keep it going.
A really easy way to do it is put an undergravel filter in your 10 gallon tank, Use a couple of compact florescent bulbs in an incandescent canopy, leave the lights on all the time and over feed your fish. Throw some snails in to keep the glass clean, but before long I'm sure you'll have a thriving garden of hair algae. I collect handfuls of hair algae from a similar set up every week.
