As my sig say's I have one Fluval running at this time. In an other post they talked about plant movement. Where I have the out flow hose now the water goes into the center of the tank and just makes the surface move slightly, not the plants. I see others who are using two canister filters. Is this just for a bigger bio-mass? I have another filter but can't figure out the configuration. with two I would have a in and an out on each side. That's does not sound effective. You have talked about the advantages of adding a power head would that be opposite the output of the canister? With or without a second filter. That seems like a lot of stuff in the tank. Without CO2 how much current should I have and where do I put it. I saw the companies X pattern with two power heads but do I need two? Could I use the X pattern with one being the filter?
I know I have a lot of questions Warning more in the future
