I am thinking that my BBA problem, maybe due to my PlantGuild Power Reactor 200, not being efficient. Every 2-3 days the sponge plugs with BBA, mulm or some other debris, causing the main cylinder to fill with a pocket of CO2. Also at app. 3 bps, the d/c stays green (with 4KH solution). I do regularly clean and do filter maintance as well as weekly water changes.
I am looking at purchasing Rhinox 5000 Diffuser to replace the above reactor. My initial question is this....................is this unit intended for corner placement only?
If it is then I would have to mount it in the front corners of the tank, as the back corners have Eheim intake tubes, and the back channel of the tank cover has been cut out to fit these tubes. I was thinking mounting these diffusers in the front corner would detract from viewing the rest of the tank.
Question #2.
We have been advised to mount 2 Rhinox 5000 Diffusers, (with CO2 splitter) in our 72 gallon bowfront tank to optimize CO2 dispersal. Although we do have 2 large ornamental heads, which might be blocking some CO2, we were wondering if this idea was not over kill.
I have read the threads on Rhinox Diffusers, as well as Tom's thread on PlantGuild's reactor,( I am not interested in a DYI project involving CO2, due to my parrots.) in this forum, and still have the above questions.
As always,
thanks for your time and iinput!
Question #2.
As always,
