im an aquarium idiot.. please help!
Discussion in 'Are you new to aquatic plants? Start here' started by inv1510nxtarz, Apr 8, 2008.
  1. inv1510nxtarz
    inv1510nxtarz Junior Poster
    Apr 8, 2008
    10:22 PM
    i recently just downgraded to a 20 gal long and im sooooo very interested in a planted tank with out all the high tech maintenance. heres what i have and what im going to get... any advice on how to setup and maintain my tank?
    have:
    20 gal long
    standard florescent lighting 20w
    aquaclear filter for 50 gal
    natural colored gravel (may not use this)
    powerhead
    heater
    get:
    eco complete
    llots of ow to mid light plants; mosses, grasses, anubias, etc...
    6-12 schooling fish
    do i need to upgrade my light or can i just stick a different watt bulb in the fixture?
    can i layer gravel on the bottom and the nutrient rich substrate on top?
    what types of ferts do i need and how much per week?
    water changes?
    $40 co2 injection system?
    what the hell do i do for my specific set up?!
    help!
    tasha
  2. Mooner
    Mooner Lifetime Charter Member
    Jun 9, 2006
    306
    10:22 PM
  3. Carissa
    Carissa Guru Class Expert
    Jun 8, 2007
    678
    10:22 PM
    You'll need a new fixture with two bulbs, most likely. Or you can overdrive the light you have with a ballast meant for four of the same length light. Wattage has to do with length of the bulb so I don't think you'll just be able to get a brighter bulb for the same sized fixture without doing modifications in some way. DIY co2 is the cheapest option, if you want to do co2. Other options are Excel or non-co2. Fertilizers are cheap. You need KNO3, KH2PO4, K2SO4 and a trace mix. Also GH booster if your GH is below 3.
