If Someone Is Interested, The Calculator Is Wrong...
Mike Workman
Subscriber
Mar 29, 2015
23
13
68
Saratoga, California
www.weenersleap.com
Be happy to walk that someone through some illustrative examples via phone or email.
I think this screen says a lot:
Dosing 1 ppm every 4 days shouldn't cause the concentration to increase every day. Plant uptake of .20 ppm /day should cause the concentration to decrease daily, only increasing on days we dose. As should the daily 4.6% water changes cause the concentration to decrease.
Initial Concentration ppm 3
Dose ppm 1
Dose Interval (days between) 4
Plant uptake per day 0.2 ppm
Plant uptake per hr. 0.008333
Water Change Percentage 4.6%
Water change interval (days) 1
The concentration over time should look like this:
My results are available in hours, this causes the lines to have a slope to them as there are multiple points per day (6).
If I am wrong I would appreciate any corrections. Thanks
Seattle_Aquarist
Aug 31, 2008
512
28
Seattle, WA
Hi @fablau
Also, I believe the Plantex CSM analysis is missing one of the nutrients, magnesium. Plantex states that 1.5% of the mix is magnesium but when I do a calculation the results do not show the magnesium. BTW, the calculator is great!
-Roy
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
3,021
683
53
Laguna Niguel, CA
www.fablauplants.com
Hi @fablau
-Roy
Thank you Roy for your feedback. Actually, I see the Mg component in the results for Plantex CSM+B. Am I missing anything else?
Thanks again.
Fab.
Reactions: Seattle_Aquarist
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
3,021
683
53
Laguna Niguel, CA
Dose ppm 1
Ok, try again and let me know if it works correctly now ;)
Thanks for your feedback!
All the best,
Fab.
Mike Workman
Subscriber
Mar 29, 2015
23
13
68
www.weenersleap.com
It seems to work correctly now - the results pretty much match my simulations, in detail and the bigger overall picture of what should be happening.
Thanks. Glad I made the comment I wasn't sure anyone would care! Not sure if this is the same as the Zorfox site, but his is wrong too.
M
Seattle_Aquarist
Aug 31, 2008
512
28
Seattle, WA
Thanks again.
Fab.
Hi Fab, Yes, it is in the Plantex CSM+B but I was looking at "CSM CHELATED SECONDARY MICRONUTRIENTS" is that different than Plantex CSM?
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
3,021
683
53
Laguna Niguel, CA
M
You are very welcome, no problem. The RotalaButterfly project is not related to Zorfox's even though both may use similar base codes for the calculations, hence sometimes they give the same results (and errors). RotalaButterfly was actually derived from old Wet's calculator we all used so much in the past, and it was reworked by me and Jason.
Please, keep the feedback coming, whenever I can, I'll fix any bugs and issues!
Thanks again :)
All the best,
Fab.
Reactions: Hanuman
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
3,021
683
53
Laguna Niguel, CA
Ok, sorry for the misunderstanding. That'll give you just "micronutrients" compounds, therefore Mg is out (that's a macronutrient). Does this make sense?
Thanks again :)
All the best,
Fab.
