Ideal water parameters for Hornwort
Discussion in 'Aquatic Plant Species' started by evangemeren, Feb 27, 2014.
  1. evangemeren
    evangemeren Junior Poster
    Oct 5, 2013
    19
    3:30 AM
    Even though i have heard from many sources that Hornwort is supposed to be a very hardy plant, I seem to manage to be able to kill it within a week or two every time.
    I am trying to use it as a nutrient sponge to absorb excess nitrogenous waste, as well as provide a supplementary food source. I am trying to grow it free-floating in a refugium separate from my main display tank. My primary aquarium inhabitants are aquatic turtles which will eat it straight away if I try and keep it in the main tank with them.
    The refugium is supplied by water from the display tank via a built-in overflow ... the refugium is an Aqueon ProFlex Model 2. The return pump is a Tunze 1073.05 variable speed DC pump that passes around 450 GPH back to the display tank.
    The refugium has a dedicated Aquaray GroBeam 1500 ultimo LED tile (6500K) so I think I have more than enough light.
    I have a pressurized CO2 system (the "Ultimate CO2 System" from Green Leaf Aquariums) with a 60mm Atomic Diffuser in the main compartment of the refugium, with a Milwaukee MC122 pH Controller set to switch off the solenoid when the pH drops below 7. I also fertilize with Seachem's Flourish twice per week according to the instructions on their label.
    I prepare all my water from a Spectrapure RO/DI unit, and then re-mineralize the water using Seachem Equilibrium and buffer using a 2.5:1 ratio of Seachem's Alkaline Buffer to Acid Buffer.
    I perform a 25% water change every week.
    My water parameters are pretty much rock-steady at a pH of 7.5, GH of 3 meq/L, and KH of 3 meq/L. Water temp is 78 degrees F.
    So ... what am I doing wrong?
    I have tried purchasing Hornwort from several different suppliers, but no matter what I do it dies within a week or two.
    Thoughts?
  2. Asmack Arabia
    Asmack Arabia Banned
    Nov 1, 2012
    145
    3:30 AM
    i suspect there is not enough macro nutrients in your water. did you test for those?. an excess of copper levels could be also. i found hornwort likes still or very gentle water.
