Hi happi,
I hope you are enjoying the holidays.
It's just a little painful. I am trying to learn as well. Looking at another person's question and trying to work through their problem increases my understanding. But, I do get strained a bit with the workout and sometimes give fuzzy advice.
:gw Having said that, let me suggest you start to verify what you read and question the advice people give you, not take it on face value. I often learn more when I'm mildly argumentative or try to validate an idea. As an example, if you read Greg Watson's thread, EI light: for those less techy folks,
Algae related answer:
The Koralia 1 is a good idea, 300gph is probably on the low end of flow that you would want for your 50. I think, I've read Tom uses a 250gph filter in his 20 gallon tank. But, other then flow, when you use the EI method, algae is most often a light problem (too much) or a CO2 problem (too little). Without knowing much more then that, you can be confident that it is there were your algae problems will be found.
Best wishes,
happi;44807 said:i hope am not bugging you in any way.
you will see that the CSM+B stock solution given in the thread is twice the concentration I recommended. Until your plants grow in and your tank is heavily planted the amount I suggested should be fine to start with, but I would recommend you go back and read the EI guidelines and follow EI dosing as it is described. Later you might make stock solutions or reduce the amounts you dose as you choose.nipat;44744 said:
Low dissolved oxygen and high ammonia are the 2 water quality parameters most likely to kill fish directly.happi;44807 said:i know that fish could die from adding too much nitrate. is there any of the other chemical which has the same effect if overdose etc.
Best wishes,
