this is what i have bought and im not sure how long they would last till i run out and this will be used for 50G tank 30% water change every 2 weeks or 20% water change every week. i have nova extreme 108 Watts 2x 54 each 10,000k and pink bulb for plant growth. Co2 with 3BPS, stays green on check drop. what do you think about the WPG because its only 108W, the fixture is T5HO and it makes about 2.16 WPG. am planning on growing high light plants such as HC.
this is what i have bought:
CSM+B Plantex
Mono Potassium Phosphate
Calcium Sulfate
Magnesium Sulfate
already have Nitrate
it would be nice if you could give me a guide to add each of them or how to mix them with 250ML water. i will be using 250ml bottle for this. should i store all of them in the refrigerator or keep them in dark under 70 degree room temp.
i could also do the dry method but need advise on how much to add and what kind of tool is needed to add this.
please do let me know about how long this stuff would last before i need to buy more.
thank you
CSM+B Plantex
Calcium Sulfate
Magnesium Sulfate
thank you
