i am having hair algae growing on plants and sand gravel
happi
Dec 23, 2009
27
i start having algae problem, it looks like hair algae, it seems to growing on glass and plants the most. but i seen some on the sand substrate also. any help please
50Gallon tank
CO2 diffused by red sea 500(drop checker stays at lime green after 6 hours)
108 watts of T5HO
koralia 1 for extra flow
rena xp2
water type - Hard
Dosing:
DAY 1:
50% water changes (day 1) adding 2 of 1/4 teaspoon of magnessium sulfate and 2 of 1/4 teaspoon of calicium sulfate.
NEXT DAY (day 2):
5mL KH2PO4 stock solution
10mL KNO3 (Nitrate) stock solution
NEXT DAY (day 3):
5mL CSM+B Plantex stock solution
NEXT DAY (day 4):
NEXT DAY (day 5):
NEXT DAY (day 6):
Nothing
NEXT DAY (day 7):
start back at day one
similar problem in the past please do read it if you get a chance:
http://www.barrreport.com/showthread.php/6773-i-just-bought-my-fertilizers-and-need-some-help
dutchy
63
The Netherlands
I had the same when I was using 118 Watts for 12 hours on a 53 gallon tank. When I took it back to 70 Watts for 10 hours it got a lot better. I still get a little bit when plants reach the top of the tank, so now I'm going to raise my lights around 6 inch.
IMO it's no nutrient issue or CO2 issue, since my CO2 is already at the limit, using the fish as a limitation factor.
Dutchy.
