Hygro Turning Red & Macrandra Showing Deficiency Signs
Discussion in 'General Plant Topics' started by Neil, Nov 19, 2018.
  1. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    Hello guys ... !
    Its been a month and a half now ..!
    It seems Rotala Macrandra isn't doing good and that reddish tint on Hygrophila Leaves confusing me...!
    Its been a couple of weeks now since the HC leaves having red pigmentations on it...
    Is it something to worry about ?
    Monte Carlo isn't spreading... Too stunted growth..!
    I need help to figure out the deficiencies my plants are having ( IF THERE IS ANY).
    I dose EI .. Except Nitrate, Calcium & Magnesium missing.
    Water parameters ...!
    GH= 18
    KH=17
    Nitrate = 40-50 ppm ( fluctuates )
    Phosphate = 0.5-1 ppm
    Ammonia = 0-.25
    Nitrite = 0
    pH = 8.3-8.4 Degassed .. 7.3 When CO2 On..!
    WATER Temp = 27 °C
    Photoperiod = 7 Hours no break.
    Light = 232 w ( 100 watt flood light + 22w x6 tube ) all LEDs
    Tank size = 48 W x 18 D x 30 H inches.
    Total Water 367 L Display Tank + 50 L Sump
    Pressurized CO2 used ..!
  2. Seattle_Aquarist
    Seattle_Aquarist Guru Class Expert
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi Neil,
    Welcome to The Barr Report.
    What products are you using for your micro-nutrients and macro-nutrients?
  3. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    All raw chems.
    Ferrous Sulphate
    Nitrate SKIPPED [ TOO HIGH IN WATER
    Mono potassium Phosphate
    Magnesium Sulphate
    Chelated Traces
    So far I was using Seachem .. But now switched to EI .. Dosing as per EI prescribes
  4. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil,
    What I notice on the photo below is how the new leaves have green veins but much lighter leaf material between the veins. This is called interveinal chlorosis. There are several things that can cause interveinal chlorosis but the most common one when it happens on new leaves is a lack of iron.
    [​IMG]
    Yes, you are dosing iron however is it available to the plants? The availability of the iron in ETDA chelated iron (the most common chelate- as in CSM+B) drops substantially to plants as the pH increases above pH@6.2 At at pH of 7.2 likely less than 5% of the iron being dosed is available to your plants. I don't have any experience with Iron Sulfate so I cannot say if it is available to your plants or not.
    What I suggest is picking up a bottle of Seachem Flourish Iron, which is made from ferrous gluconate. If you cannot find the product, or ferrous gluconate, see if you can find some EDDHA chelated iron (it will tint water red) or the next best would be DTPA chelated iron.
    When you start dosing the new source of iron do not watch your existing leaves, they likely will not change. Instead look at the new leaves as they emerge. They should look greener, healthier, and the interveinal chlorosis we see in the photo should not be present.
    Keep us posted as things progress! -Roy
    [​IMG]
    Neil, Tariq Kieran and sarpijk like this.
  5. Julia Adkins
    Julia Adkins aquariumfertilizer.com
    Jun 22, 2015
    172
    42
    11:13 AM
    Aquariumfertilizer.com carries dry ferrous gluconate. I like its excellent solubility, nonpowdery texture, and affordability.
    Tariq Kieran likes this.
  6. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    Hello Sir,
    Sorry for the late reply ... was having very tight schedule so far.
    Anyways ... i tried Both Seachem's Iron Gluconate and EDDHA...
    FeEDDHA 6% was super fine i must say ...
    Due to high pH Seachem Iron was precipitating... That's where things went wrong.
    I'm attaching the current snaps... leaves are looking alittle better than before.
    Right now only one thing is troubling me ...
    Ive started using RO water (Last tested results : KH= 9 GH=14 pH=8.2 (degassed)/ pH=7.2(Dissolved CO2) & Nitrate= 25 ppm)
    Earlier KH i had 20 degrees.. that was way too high...
    As you can see here my KH has reduced significantly but still pH isn't changing at all ... and 8+ pH putting stress on my plants.
    So far I've reduced KH by diluting with RO (pH= 6) water ... 20% WC every 3rd day.
  7. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil,
    Keep up the iron and the dosing of other nutrients as you have been. Have you discontinued the magnesium or are you still dosing it?
    Specifically what are you using for "Chelated Traces"?
    #7 Seattle_Aquarist, Dec 1, 2018
  8. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    Yes sir.. Still dosing ..
    Started using RO water... so im dosing Epsom Salt ... dosed alittle yesterday, would increase gradually if i don't see any signs of stress on my fish.
  9. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil,
  10. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    For traces I'm using EDTA Combi
    Link: https://www.direct2farmer.com/EDTA-Combi2-25
    Since it has a little higher copper content so I'm dosing it weekly....1 tsp in dosing bottle ...10 ml dose weekly.l
  11. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    OK, so you are putting 1 teaspoon in a dosing bottle. How many ml in the dosing bottle so I can determine the ppm's of the various nutrients being dosed.
  12. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    500 ml bottle ... 10 ml dosing
    TOTAL Water 420-430 L ( Display + Sump)
    Plant load: Moderate I would say ..( too many species but not full grown) except a few.
  13. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    No Sir ... for Iron im dosing Fe EDDHA 06 % separately...! (Since my water quality is abit in the basic side)
    Trace has Iron in it .. but im not relying on it for the Iron.
    My Dosing list:
    RO Water 41 TDS
    Dosing bottle as i mentioned earlier
    Nitrate : Skipped (Even RO water has ~20 ppm)
    Phosphate : 1.5 ppm maintained
    Potassium: 10 ppm
    Calcium Nitrate & Magnesium Sulphate= 10 & 6 ppm respectively.
    Iron = (About 70 grams in 500 ml water)
    Trace as i mentioned earlier...
    Macro & Micro Alternate Days dosing...!
    #14 Neil, Dec 1, 2018
  14. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil
    Actually I was looking into the possibility of a boron (B) deficiency; when I did the calculations it looks like you are only dosing .0012 ppm of boron (B) where typically we look at 0.06 ppm of boron. That is why I asked @fablau to check my calculations.
    That calcium nitrate may have something to do with your Nitrate levels.
    How many times a week are you dosing the calcium and magnesium?
    Please just call me Roy
    -Roy
  15. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    P&K (Alternatively)
    Cal (10 ppm) & Mag (6 ppm) in Macro days but twice a week
    Iron Alternatively
    Trace- Weekly (The day i dose Iron).
  16. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil,
    Let's see if @fablau checks comes online in a day or two and can help us with the estimated dosing levels of your micros.
  17. Seattle_Aquarist
    Aug 31, 2008
    488
    92
    3:13 AM
    Hi @Neil,
    Also, with a dGH=18 I would see if you can find some Potassium Nitrate to replace the Calcium Nitrate. Why? It seems that you may already have 'hard water' and adding additional calcium is not helping. Also excess calcium can effect the uptake of two of the major nutrients, potassium and magnesium.
  18. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    Hello ..
    Please don't follow that dGH figure that's a week old now ... I've started using RO Water as I said ... I can tell you today's result... dGH 11 and dKH 8... And the figure will reduce day by day ... As I do 20-25% water change every 3rd day with RO water ... RO water will dilute the hardness over time ...
  19. Neil
    Neil Member
    Oct 15, 2018
    30
    4:43 PM
    YYess .... Calcium toxicity ... May be !! I'll have a look at it then ..
    Its better to hold down the calcium dosing as still my tank hardness KH 8 ...in theory enough Ca should be there ...
    I'm targeting KH 2 ... for Toninas ... !
    Seattle_Aquarist likes this.
