How to wire a Burkert type 6011 solenoid
alanle
Jun 10, 2013
210
14
Josh It comes with the din connector if you look on picture 3. 24v adapter is also available on ebay.
oldpunk
Dec 1, 2009
427
My bad, I didn't see the din. I guess that's what happens when you post before 5 am.
18,696
747
Alan, link the 24v adapter for the helpless that often read these threads :)
oldpunk
Dec 1, 2009
427
Unless I'm missing something again, that's a D/C converter. You need 24VAC. (When you see a burkert that has a hertz after the voltage, it's A/C. The D/C coils clearly say a D/C.
alanle
Jun 10, 2013
210
14
no you didnt miss anything. I didnt realize it was 24vac even though the title clearly says 24vac:). You learn something new everyday. That ebay seller also sells 24vac power adapter.
Reactions: 2 people
Matt F.
2,319
California
I personally like the clean look of a standard and robust 18/3 gauge power cord. No converter needed. I've bought all of my solenoids from either iprocessmart.com (which is an authorized Burkert dealer) or aquariumplants.com. The late Left C arranged a deal with freshwatersystems to carry the correct solenoid/DIN, etc for us. No converter needed. It's literally plug and play with a coil that is designed for the amount and type of power coming out of an American wall socket. If you go to ebay and buy surplus, make sure to get the correct converter otherwise you can catch things on fire.
Flyinghellfish
Dec 26, 2011
69
Good thing the solenoid is hook up to a Co2 cylinder and a glass box full of water. It's literary the best place for a fire to start. :D I'm just playing with you man. Any of you guys hook up the solenoid to those "brick" adapters? It's like a laptop ones with the extra cord on the other side, it drives me insane when one plug takes up two sockets.
Matt F.
2,319
California
Please don't say anything about fires! LOL I read a thread a while back were a solenoid started to smoke. Not good. ;p
oldpunk
Dec 1, 2009
427
I think it was a d/c burkert wired for a/c. (Or vise versa) I vegly remember the thread.
Daniel T
Feb 27, 2015
6
Thanks for the excellent step by step instructions. I wired mine today and it worked perfectly. The solenoid does get pretty warm so I might add a small heat sink to help cool it down a little.
superflame
May 10, 2011
84
It's normal that the burkert get a little warm. I have been using mine for 3 years now and does not produce any heat under my cabinet. You shouldn't be worry since, most hobbyist including myself been using Burkert 6011a for years. However, in rare situation you may get a bad unit and those will leak. If no issues within 1-2 month of usage. It will last you a life time.
Stevek
May 23, 2016
Thanks for the excellent step by step instructions, this is great for salt water aquariums as well !!!
