A great alternative to JBJ bubble counters on your DSR (Dual Stage Regulator) build is Swagelok part numbers:
B-6MO-1-2
http://www.swagelok.com/search-results/search-results.aspx?qs=b-6mo-1-2
and
B-6M5-4M
http://www.swagelok.com/search-results/search-results.aspx?qs=B-6m5-4m
These parts work together to create a leak-free locked seal between the CO2 tubing and your regulator post body.
Below are some pictures to help you install this adapter correctly. There are no directions, a few diagrams if you search the Swagelok site, but it's good to have a reference when using one of these for the first time.
Part number SS-6MO-1-2 is seen in this picture on the right. Part number SS-6M5-4M is on the left:
Exploded version of part number SS-6MO-1-2:
Those two inner parts are ferrules, which hug the hose and hold it in place once tightened.
B-6MO-1-2
and
B-6M5-4M
