Hey guys,
I'm trying to increase my co2 level, the problem is though that my fish are already at the surface as it is. How can i increase my ppm without increasing death
My drop checkers are always yellow?
I'm running 3 reactors, one diy reactor with 20mm - 3/4 intlet outlet and clear 50mm (2") plastic pipe approx 30cm(1') long. The other is a sera 1000 reactor with 16/22 outlet/inlet and an ista brand reactor with 12/16mm hosing. Diy reactor is being pumped by a rio 1100 pump, the sera reactor has 1500l/hr and the other is running on an eheim 2217.
I also have 1x 3000l/h wavemaker and 2 x 2000l/hr nano wavemakers for added flow, which brings the tank around 8-10x volume
Also the tank has light surface rippling over the entire surface without breaking it.
Tank is 500L , 130g is 28" deep, 24"wide and 48" long
I've now reduced my lighting to 2 54w globes to see if that helps, I've recently recieved some ludwigia brevipes which have shown some drooping crowns. However growth is rather fast still. My ludwigia cuba hasn't started growing like it was before i had deficiency. I'm wondering if these plants are slow to recover from deficiency?
Main Question
Is how i push higher levels?
Could too much fish cause the fish to go to the surface prematurely?
Could tank depth vs surface area have any impact?
Can i increase my reactor diameter and length and install a higher flow pump to churn up co2 greater and faster?
Sam
Main Question
Sam
