How To Mix Up 13% Chelated Iron
Discussion in 'Aquatic Plant Fertilization' started by Fishfur, Aug 11, 2018.
  1. Fishfur
    Fishfur Subscriber
    Oct 16, 2016
    13
    11:27 AM
    Just began mixing my own DIY ferts. The macro mix I think I've got sorted. And the CSM+B.
    But, there's also a bag labeled 13% chelated iron, with the assorted bags of fert ingredients I got. There are no instructions on how to use it.
    There is no information on what else it contains, should I assume it's EDTA?
    I was using Seachem's Iron, I'd like to use this instead. I will when I know how to mix it and how much to use once it's mixed.
  2. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,300
    5:27 AM
    You can *probably assume that it's edta since that is a common % edta comes in. It's listed on rotalabutterfly
    Either way, 13% is 13% so you'll get the same ppm regardless
  3. Fishfur
    Fishfur Subscriber
    Oct 16, 2016
    13
    11:27 AM
    I'll have a look. Thanks.
  4. burr740
    Feb 16, 2015
    1,398
    1,300
    5:27 AM
  5. Fishfur
    Fishfur Subscriber
    Oct 16, 2016
    13
    11:27 AM
    I need help with the calculator. If I'm honest, I'm a math moron. Always have struggled with numbers. Ideally, it would be lovely just to be told how much of my iron mix to add to a 500 ml bottle of RO water.
