How to manage tank during vacation??
Discussion in 'General Plant Topics' started by kevinmichael77, Nov 29, 2014.
  1. kevinmichael77
    kevinmichael77 Guru Class Expert
    Oct 5, 2012
    385
    7
    1:21 PM
    I am going on a 9 day vacation at the beginning of January and I'm not sure how to manage my tank. It's a high tech set-up and Ei dosed daily. I will change the water the night before but can I add the nutrients all in one fell swoop? I can have someone feed them a couple times but don't want to burden them with stopping over and dosing the tank everyday.
    Appreciate the help and advice!
    Kev
  2. gsjmia
    gsjmia Lifetime Members
    Jan 10, 2010
    327
    19
    1:21 PM
    There are numerous threads on this forum about this. This is typical: http://www.barrreport.com/showthread.php/6451-Vacation?highlight=vacation
    Do the things that Gerry describes.
    It helps if you have autodosing and a sump.
    I have autodosing, so that was not an issue.
    I have a sump and was worried about evaporation-so I filled the sump to the top, and then got several 5 gal buckets and treated them with dechlor and filled to the top, then added small siphon hoses from each bucket to the sump, as a water reserve.
    Ehiem makes a nice auto feeder.
    Or you can do as Tom recommends, hire a kid-put the EI doses in a daily pill counter.
    - - - Updated - - -
  3. kevinmichael77
    Oct 5, 2012
    385
    7
    1:21 PM
    I have a sump but no auto dosing system.
    So I couldn't just put a weeks worth of fertz in all at once. I can have someone come over after a few days to check the water level but not every day to Ei dose.
