How to make iron stock solution
Jeremy1
Aug 12, 2008
64
I just got some iron chelate from GLA. How should I go about make a stock solution and how much should I dose and frequency? My currently dosing EI plus CSM+B.
Thanks,
Jeremy
nipat
May 23, 2009
665
GLA doesn't tell percentage of the iron. So, it can't be calculated.
Jeremy1
Aug 12, 2008
64
ordloh;42939 said:
If it's pure dtpa-iron then it should be about 12.5% iron.
This is what GLA states about their iron. "The nice thing about our Iron Chelate is the DTPA factor combined with EDTA iron in CSM+B. What you have there is basically PMDD of TMG, expect really nice results from our Iron :)"
Do I really need to make a solution or would it be possible to just dry dose it?
Thanks,
Jeremy
I'd just mix with the CMS+B at 1/4 to 1/3 by weight, then dose that as you did prior.
Jeremy1
Aug 12, 2008
64
Yes, that is much easier. I sometimes make things harder than really need to be. Now, I just need to get a good scale. :)
Jeremy
DaBub
Oct 18, 2009
102
Jeremy
A good scale won't hurt. ;) If you think about it in this case a good scale is just anoter complication. :eek:
Adding a quarter to a third more isn't exactly an exact measurement. :p
Here is to life; uncomplicated! :cool:
Yes, certainly +1 for making it easier, I think you should be able to eyeball the 1/4 to 1/3 by weight pretty well.
A scale can be had for 20-30$ tops on line for 2 decimal places, or 10milligrams, a few more $ for decent 0.001 gram scale, maybe 80-120$ range?
Not a bad thing to have if you want to be more precise, but it will not help you really become a better horticulturist.
