How to emmerse a Sword?
Ok, I'm bored and some of my swords are busy clogging the whole tank with plantlets.
Since swords are bog plants I had this idea to take one or two into work and use them as desk plants. My first attempts have resulted in shriveled little husks of plant. I had initially planted them in some miracle grow organic and just flooded the pot to the top of the plant and let the water level drop over time.
Does anyone have any good pointers on how to transition plants to emmersed growth for long periods or is this just a case of me not covering/misting them enough until they got established? Maybe there wasn't enough light? Maybe too many variables changing too quickly?
over_stocked
Jan 3, 2010
Brandon, Sd
I am interested in this too. I have a new riparium setup and tried this twice with no luck. I misted 3 times a day. I guess the reality is that the heat is really drying out my house(tank is losing 2 gallons a day...).
jonny_ftm
Mar 5, 2009
821
It's only a case of moisture. You need constant above 70-80% humidity. Misting is a no go on the long run as they will develop mold. If you cover them (tropical terrarium), ventilation must be adequate and soil dry on surface to avoid mold
They will grow just like emersed setup. Look here for "dry strat" or google "tropical planted terrarium"
C
csmith
I'm currently doing micro swords. The heat is the biggest issue as far as I've seen. Nightly after the lights turn off I open the tops for 30-60 seconds to allow gas exchange and release the heat. I've actually been misting some areas of mine, but only those plants directly under the lights as they're the ones that dry out. Just keep an eye on it and you'll be fine. jonny_ftm's thread actually helped me out a lot.
SuperColey1
Feb 17, 2007
503
47
Lincoln, UK
I don't bother with this water above the plant and let it fall. Neither do I expect mould from misting!!! If you have problems with mould or cyano when misting then just add 10 drops of pure tea tree oil to each litre of misting water (or if you have a 500ml spray mister bottle then 5 drops) It is antibacterial but also kills off mould.
Swords are hard to do emersed. I had to spray several times a day and eventually got bored and gave up with them. They are so prolific within a tank that keeping 1 will mean a never ending crop.
If you don't mist then they tend to dry out on several leaves so you end up with green centres and brown dead leaves on the outer. I kept them in standard under bed storage boxes with cheapest you can find compost filled water to the surface of the compost and HC, Lileopsis Braziliensis, moss, Crypts, Anubias, Ferns etc all in these boxes. Inside thehouse, under 14 hours of light. Everything does well with no misting at all except for the swords.
AC
jonny_ftm
Mar 5, 2009
821
Using fongicids and other pests is really not necessary.
Growing crypts and anubia inhouse, exposed to ambiant air, is a no go for most people living in 50% and less air humidity. I even doubt Anubia and crypts can grow with its roots in the air for a long time in anything under 60-70 ambiant humidity
Chain swords grew with no issues (removed them because they were really invasive), without misting, with just a humidity above 80%
