How to deal with spirogyra
18,695
736
Yes, trim it off, pull out plants and strip the algae off them, then replant. Adjust the CO2. Clean filters, 2-3x a week water changes, peroxide and Excel. Some folks use the algaefix, but it will kill some shrimp, Amano shrimp are the more touchy of the species, RCS are pretty resistant, but you might lose a few of them.
When my gas tank ran out, that's when I get the various hair algae, otherwise it's rare.
It's a lot of labor basically to stop it and clean things up.
Somewhat the case for most algae.
Different methods, causes etc, but the basic routine is fairly similar. Remove what's there, fix things generally, care for the tank more............
azriazmi89
Oct 9, 2017
31
malaysia
Thanks tom for your quick reply. I will try your method first then will update it back later. Fyi, my tank was running with high light, high nutrients and high co2 but suddenly 2 weeks ago this spirogyra appears.
18,695
736
That's a great method to get algae if something goes wrong(High light, ferts, CO2).
Try low light, rich CO2 and moderate ferts.
You rarely have issues.
If you have higher light, rich ferts and CO2, you need to care for it. Trim, water changes, cleaning etc.
More advanced folks can get away with some things, but generally............
azriazmi89
Oct 9, 2017
31
malaysia
Noted! I think I understand it now. Thanks Tom!
Kyalgae
347
234
43
Canada
I
Would you be able to elaborate more on what you'd consider moderate ferts vs high ferts? Does it only apply to what we consider macros, or micros as well. What kind of ppm range? Or is there an older post that goes into this?
