How To Build The Perfect Spectrum Led Light.
Discussion in 'Lighting' started by Stan510, Jan 18, 2020.
  1. Stan510
    Stan510 Member
    Nov 28, 2019
    181
    9:06 AM
  2. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    970
    12:06 PM
    This has been done many ways.
    Been building these for years.
  3. Stan510
    Stan510 Member
    Nov 28, 2019
    181
    9:06 AM
    Any Barr Report tutorials?
    Nice light...for a cube or olden days hexagon?
  4. Phishless
    Jul 13, 2017
    1,116
    970
    12:06 PM
    I put them in tank canopy.
    300 watts worth over my 80G frag tank.
    Every heat sink has 6 - 15K whites, 6 - full spectrum, 1 - 460nm, and 1 - 520nm
    Reflection on water surface
    [​IMG]
  5. jeffkrol
    jeffkrol New Member
    Jan 11, 2018
    11:06 AM
  6. GreenTerror
    GreenTerror New Member
    Jun 6, 2020
    9:06 AM
  7. jeffkrol
    jeffkrol New Member
    Jan 11, 2018
    11:06 AM
    Mouser or Digikey.
    Smaller version (spectrally so close as to be possible measurement error)
    Part of their sunplus series.
    https://www.stevesleds.com/Luxeon-SunPlus-Cool-White_p_355.html
    Be aware of the large beam angle though. Probably best to use reflectors or really close to the water surface.
    One thing though LED tech is really moving fast and Bridgelux has a COB/chips that are equiv or dare I say better.
    Vesta Thrive series.
    Available at Mouser or Digikey.
    https://bridgelux.com/products/vesta-thrive
    [​IMG]
    Apparently runs 2 types of blue plus phosphors in each COB.
    If one wants some added spectrum one COB to look at is Lumileds "crisp white"
    Lower K temp (3000-ish) but adds some violet on the COB to "whiten" things.
    Some people may appreciate the violet..
    https://www.lumileds.com/wp-content/uploads/files/DS168-luxeon-cob-with-crispwhite-technology-datasheet.pdf
    [​IMG]
    Pairs of "fresh fish like" and crisp white are a pretty good one two punch.
    3.5:1 (on a lumen basis) Fresh fish and crisp white estimate:
    [​IMG]
    One CRI basis Crisp White/Bridgelux doesn't chart as good no matter the ratio.
    Doesn't make it bad, just different.
  8. CrisChloe
    CrisChloe New Member
    Jul 16, 2020
    11:06 PM
    i am using this light but don't know what exactly it is...
    the seller sold as HPL, not COB or Cree..
    is it other kind of led or similar?
    so far, i am using Rotala Butterfly Calculator and depend on Cree option...
    if PAR shows 200 with 30cm from the surface with 5cm substrate it will unforgive-able for my Hairgrass... (my tanks is 50x30x30)...
    so far so good and i just make the light higher than before...
    i won't burn my Pinatifida more because they just planted there and fuzz algae start growing... my thought to give time for it to adapt well...
    but... i don't mind make it lower again depend on the vigor of the plants later...
    this is my diy Light..
    this is the tank..
    the middle line is 10.000K led... but have no idea why the color is like 6500K in the middle...
    my thought is alot phospor or any that absorb pink spectrum beside.. but i am not sure...
    #8 CrisChloe, Dec 10, 2020
    DeepMetropolis likes this.
