Just a few things since I posted this last night...(I have pressure tested the unit and these are things I learned the hard way):
1) You cannot use non-hardening thread sealer on high pressure connections...the non-hardening thread sealer will just shoot out, so I ended up reseal a majority of the regulator side threads with teflon tape. This stopped the leaks.
2) When I first connected the regulator to the gas, I heard massive amounts of co2 escaping from teh regulator. Knowing me, I though I bought a faulty regulator...turns out it was just gas escaping from the pressure relief valve. There is a hex head bolt inside that I needed to tighten.
All three connections I sealed with non hardening thread sealer leaked upon testing:
1) CGA 320 nipple to regulator body
2) Pressure relief valve to regulator body
3) post body 2" hex nipple to regulator body
The only one that did not leak after switching to non-hardening thread sealer was the low pressure gauge.
Here are pics after fixing the leaks with teflon tape. It's working perfectly with no leaks!!!
Left C~ I think the level of the bubble counter is perfect. It sit just below the top of the gauges.
Orple~ the ideal valve is in stainless not chrome. You just have to play with the pipes and adjust with a wrench...when they get tight, you can use a wrench to push it that much more...
