How To Build A Cerges CO2 Reactor
rajkm
Article Editor
Article Editor
Sep 16, 2015
679
218
43
Hillsboro, OR
While it will increase the surface area, the fine bubbles will easily get sucked into the outlet, unless you have some kind of media which disrupts the flow.
skija
352
83
28
Romania
What i can say about this reactor is that i tried both 7 " and 10 " water filter and the 10" dissolves the co2 much better and i think is because the water and co2 travels more and co2 has more time to dissolve in the water .
I don't have a sponge inside on the tube
skija
352
83
28
Romania
Anyone can confirm that if a sponge is mounted at the end of the tube the CO2 is dissolving better?
I'm asking someone who tried this not someone who speaks theoretically
Rmerriett
Jan 5, 2018
51
46
Watertown, wisconsin
Thank you so much for this post. Its the only post on how to build a ceges reactor that has a list and pictures. I bought most of what i need today, i just need a pump and hoses and im all set. Mine is built with the parts i could find so its not 100% the same. Any thoughts on the pump id need to power this? I was thinking 300gph.
Mike Y
Mar 30, 2018
37
New Jersey
Your setup looks great. The one thing I found that works is putting a low psi brass check valve between your brass bushing and barb. It’s a good spot that works well for me.
