How overgrown/thick do you let your stem plants and other plants get before trimming?
AquaticJim
Aug 2, 2007
173
How overgrown/thick do you let your stem and other plants get before trimming?
What about your Blyxa Japonica? It grows like a veritable weed in my tank and a single plant the size of a matchbox within a month or so turns into half the size of a basketball that can be then broken down into around 20+ seperate plants.
Glosso? a little bit soons turns into a giant mat thats pushing up against the glass and then go 2 - 3 even 4 layers high. I end up just lifting the whole mat up and cutting a few squares out and replanting them.
Broad leaf chainsword, pull up 300 (they all come up as a mat as well) pick out around 20 small plantlets and replant and off they go again.
Riccia...I'm over Riccia, looks nice, but what a PITA.
My tank never really looks the same for longer than 4-5 days, it's always in a state of flux. Going through either an overgrown look, a just trimmed look or getting to need a trimmed look!
The only thing that stays pretty much the same is my crypt forest.
Crispino Ramos
Apr 23, 2010
278
Phoenix, Arizona, USA
I would compare it to maintaining the lawn by mowing regularly, trimming the bushes and pruning the trees before it's overgrown. It might be a chore but a less troublesome work compared to thinning the forest.
dutchy
64
The Netherlands
Welcome to the world of good plant growth. ;) The only way to slow this down is using less light, both intensity and duration. Less photosynthesis=less growth. when using Glosso less intensity is somewhat limited, but less duration will keep your scape more stable growthwise and a lot less work.
nipat
May 23, 2009
665
It's the result of your MH light:D
I could slow it down to 3 months to get the size with less light.
wearsbunnyslippers
Apr 2, 2007
35
this sounds like my tank... i have about 2 days a month where my tank looks perfect when it is running like that, exactly as you say: "Going through either an overgrown look, a just trimmed look or getting to need a trimmed look!"
how much light are you running?
