How Much Light For My Tank?
Discussion in 'Lighting' started by eVolution, Apr 9, 2019.
  1. eVolution
    eVolution New Member
    Apr 9, 2019
    7:27 AM
    Some specs before I start rambling on.
    Tank: around 30 gallons.
    Lights: 3 LED strips, 2x white, 1x RGB
    Time controller: TC420
    CO2: none
    Substrate: Dirt and laterite
    Plants:
    Pistia stratiotes
    Microsorum Pteropus (Java fern)
    Vallisneria spiralis
    Staurogyne sp. "Bihar"
    Nymphoides hydrophylla
    Rotala rotundifolia
    Taxiphyllum barbieri (Java moss)
    If I'm correct these plants can be labeled as 'low maintenance' and 'low light'. But how much is 'low light'?
    I've been told that LED-strips are insufficient for plants, or at least bad, by several experts on a Dutch forum. But I figured it might be enough for the plants I wanted. The question is, is it enough and how many hours and how intense (how much %) do you reckon I need to turn them on?
    Thanks in advance for any information, advice and wisdom! :)
  2. Joao
    Joao New Member
    Dec 26, 2017
    6:27 AM
  3. Tim Harrison
    Tim Harrison Lifetime Member
    Jul 7, 2017
    385
    339
    6:27 AM
    It'd help if you posted a pic or two of your lights, and then maybe we could give you a more definitive answer ;)
