I have a 65 gallon with a Marineland Tidepool II and a Mag Drive 9.5. The flowrate of the tidepool is 300 - 600 gph, and with a 6 foot head and some elbows, the Mag Drive can push somewhere around that max of 600. I have it controlled with a valve.
My question is should I add another filter? I have both fish and plants, and my biggest concern is that since the pump is hard plumbed, if it were to die it would probably take a week to get a replacement put in, or I would have to take a day off work and go through all the trouble of installing whatever pump was available that day.
I was thinking about adding a canister filter to have a redundant filter. Is this recommended? Common? Overkill?
I was also thinking about having the intake to the canister be in the sump, and then output into the tank, possibly pumping through a DIY CO2 reactor. Can a canister pump 6 feet over its head?
What are your thoughts? What flowrate would be good for the canister?
