How is 50% water change accomplished?
bluedragon
Apr 21, 2010
Burlington, Massachusetts
In EI method it is recommended to do 50% water change weekly. How is that done?
When i change my water I put the new water in one container and add AmQuel plus (to remove chlorine & chioramines etc)
I let the water sit for all night in winter (because in winter the water is freezing cold) and few hours in summer.
It will be hard to change 50% water with my method. Is there a better method for water change?
I am pretty sure this has been answered, I could not find the blog. I would really appriciate if point me to correct direction.
I live in rent so I am looking for way which does not include plumbing :)
Thank you
Regards
NN
I have a 180 gal and also rent...........
1. Drain tank to desired level. I use a spare pump with hose attached and drop in tank. Place end of hose in sink or outside and let er rip..
2. Dose Prime or Amquel as required for the ENTIRE tank volume. To be safe.
3. Fill from TAP. I have another flex hose and fitting for quick connect to the kitchen. You need to ensure your tap has no major issues like copper, etc. Try and get a local water report.
It takes about 45 minutes to drain/fill 80% weekly on my tank. At the same time, I can clean, prune, maintain filters, etc.
Heavy EI dosing after each water change.
bluedragon
Apr 21, 2010
Hi Gerry
Thank you for your reply. Few questions.
1) when you say "Dose Prime or Amquel as required for the ENTIRE tank volume. To be safe." are you saying add Amquel directly in the fish tank after draining the water to desired level and fill the tank with tap water?
2) If that is correct then what about the drop in temperature? my tap water is 53 F in summer and almost freezing in winter. Should i not worry about that
Case:
I keep my tank around 80 F
and if i do 50% water change and add tap water directly (assuming my tap water temp is 40 F) then my delta in water temperature is 20 F. I will be going from 80 F to 60 F within few mins. Is that not a concern for fish? I understand fish are used to drop in temp in nature because of rain and etc but in my water change the temp will fall drastically.
Regards
NN
1. Yes. Add the dechlorinator to the remaining tank water. As you add from the tap it will work better.
2. You should be concerned about a large temp drop. That will kill fish.... Can you use a 'warmer' water temp from the tap? Use hot and cold water? Or fill SLOWLY and use a larger submersible heater IN THE TANK to help level the temp diff?
Sorry, but I live in FL where water temp is not an issue......
Anyone in cold climates that can chime in here?
Left C
Sep 26, 2005
2,500
69
Burlington, NC
This is what I do.
  • I use a Python for draining and refilling. http://www.pythonproducts.com/aqprod.html
  • After draining into the sink, I dose Prime for 100% of total tank volume.
  • I use tap water from the kitchen sink faucets with the cold and hot water mixed to be close to the same aquarium temperature for refilling.
  • Add ferts.
Maintenance is done in the middle of this cycle.
ibnozn
Mar 7, 2008
46
I use hot and cold out of the tap to get the right temp without any problems.
Most hot water heater tanks are glass lined so I don't know how it could add contaminants.
I use warmer water by mixing at the faucet. It does seem that water heaters could add some amounts of copper and reduced O2 levels from the heating process. However, mine has not had any issues that I could tell and 80-90 percent changes have had no ill effects on my breeding panda cories or the shrimp in that tank. I do have shrimp mortalities but no in the amano shrimp and the water changes seem to have no increased incidence. I.e. I don't find any correlation with a WC and any dead shrimp.
Crispino Ramos
Apr 23, 2010
278
Phoenix, Arizona, USA
Are you saying, you do an 80% partial water change weekly? By heavy EI dosing, how much/specific amount is heavy dosing?
jonny_ftm
Mar 5, 2009
821
I have space to keep a 120L (30gal) + 30L (8 gal) containers. I prepare RO water purely to which I a add MgSO4 and CaCl2. Water stays sometimes a week or 2 apart once prepared. No need to any additives
Yes, that is what I am saying.... Sometimes I do 2 or 3 weekly if I am managing an issue or really looking to make things look extra good. Water changes are a good thing...
I dose the following 3x weekly:
2-3 tsp of potassium nitrate
2+ tsp of momo potassium phosphate
20-30 ml of trace TNG
I intermittently dose with Excel at water chage time. Only the water change dosage and never more than that.
When I do the water change, I up each dose by 15-25%.
Currently as I want things to grow in I am doing 2-3 80% WC, heavy dosing, ensure good c02, etc.
Over the next 3-6 weeks I will reduce this to 2x weekly than once weekly as usual..
