How do I grow Ludwigia arcuata fast?
detlef
239
68
Cologne, Germany
I'm having a hard time growing Ludwigia arcuata "fast". Whereas a healthy 10cm stalk of R. rotundifolia reaches the top in about 3 weeks a comparable arcuata stem needs about 2,5 to 3 times longer under the same irradiance and fertilizer amounts (including CO2 mist). Is this normal or may I have a slow growing species? Does the arcuata need "special treatment" to get a spurt? Or is this what I'm observing simply the difference in light demand? Tank is running on round about 2w/g.
Thanks very much,
Detlef
775
Under higher light, about 2x, I grew this one really fast, but biomass is bushy, not so much vertical. I had hard water(KH12, GH24), good CO2, standard plain old EI dosing
I had it as a main plant for 3 years in several tanks.
It has a different growth pattern than R rount.......
Submersed it gets bushier and more roots, tangles almost.
2-3x slower vertical growth is likely about right.
Top the R rount and wait for the L acurata to catch up.
detlef
239
68
Cologne, Germany
Thanks Tom,
yes I can see how bushier growth patterns impact the speed of vertical growth.
Anyhow, when I look at some Arcuata shots around the net I really can get jealous wondering how that could be achieved.
Arcuata has its leaves 1,5 hrs longer unfolded vs. R. rotundifolia (13,5hrs vs. 12hrs) and supposedly needs both higher lighting and longer light periods to grow to its full glory.
Best regards,
Detlef
775
Well, here's the the tank I did:
I hacked it back aggressively 4x a month, about 50% each time.
So it had a doubling of bass every 2 weeks.
Just flourite, rock hard water, CO2, normal EI dosing, no GH obviously, TMG etc.
I can get the plant to turn green or redder with NO3.
I have several 35mm slide pics that are real nice, but have not been able to scan them well.
Maybe it is lighting..........
detlef
239
68
Cologne, Germany
Well, I know you like playing the bass...;)
May be the Arcuata does not get sufficient light where it is growing in my tank or may be it's the water. I'm at 15ppm Ca and 3ppm Mg which is pretty low, likely a little low for this plant. I'm definately not observing the kind of strong growth you're presenting here.
I'm gonna try to find out what is wrong.
Best regards and thanks for replying,
Detlef
775
I think lighting might help.
I've not really tried to grow it under the same conditions in my softer water here, I have a A reineckii project at the moment:)
I did well with a Gh of 9 and KH of 5.5.
"Bass" and what was meant to read "mass", well, Freudian slip I suppose:)
Guilty as charged:)
dealt
Sep 25, 2007
50
That is one fiery bush of arcuata! Now I'm really jealous! How did you do that? Plenty of wpg lighting? I've 2x55wPL on 36x18x16in tank and I can't get my arcuata to get that red, worse I can't grow them standing upright, they're bending everywhere. Any tips? Thanks!
775
The growth pattern is odd with the plant.
It' does go all over, you just have to grow it fast and trim it(topping etc).
But.............I just yanked this up, then hacked the ratty bottom's off.
To get this look, I simply allowed the bush in the rear to double it's present trimmed size. So let it grow out more, then trim.
Then I went with full dosing minus NO3.
After 1 week, I trimmed and chose only the reddest stems to replant.
Just some simple trimming methods can yeild crazy red color.
Many seem to think that their plants show always look a certain redness.
Well, some parts will but often not the entire bunch.
But this is horticulture..........
I'd say the plant is similar in terms of growth as Rotala "Green".
It responds well to topping or replanting tops.
I used 110w on a 25 Gallon tank here.
Pretty high light for these days and crazy high light back then.
Folks suggested that open lower biomass tanks would get algae if you used EI.
Some suggested also that I could not do simple arrangements.
Clearly not.
This tank took a few weeks to do, then I moved on having made the point.
detlef
239
68
Cologne, Germany
Provided I read the plants right I'd say both high light and N-stress can turn red plants even redder.
Low NO3 though is much more effective than high light. But it's the combo what you want to focus on in terms of
maximum red coloration.
IME Arcuata needs more than 2 watts per gallon and low NO3 levels (1-2ppm) to turn an intense red. The downside is if you let NO3
drop too low or let it bottom out for too long a time you'll easily stunt the plant. Daily fertilization with very small NO3 amounts AND a
higher fish loading for continous NH4 supply seems to be the best long-term approach. For short term purposes I suggest keeping the
plant at higher NO3 levels and to stop adding NO3 for some days like Tom did.
Now here is some speculation on the bending issue:
Arcuata tends to grow more upright
1. if it senses strong light from above
2. if fertilizer amounts are kept very stable (varying nutrients -probably changes in temps and other parameters as well- produces more side shoots)
3. if light with kelvin ratings below 10.000K is used
Best regards,
Detlef
775
Yep, pretty good summary.
Also, light needs only to be intense for a relatively brief period, say 2-4 hours a day.
But 10- works too:)
dealt
Sep 25, 2007
50
sorry for not getting it, but is NO3 = KNO3? And the process you explained: N03 stress, won't it affect the other plants? Thank you very much!
775
The NO3 is derived from KNO3.
You add KNO3 for NO3 and for the K+.
Yes, if the NO3 limitation is strong, it will reduce plant growth and limit it.
Indirectly, low O2 from the plants, poor NH4 uptake etc can affect fish.
But less NO3 itself will not.
I do not like to run high light, high growth tanks at low limiting nutrient levels, too much work and fiddling.
A better method is using less light, it's many times easier to maintain lower levels of nutrients.
dealt
Sep 25, 2007
50
Hi, I think I got lost there. I hope you won't mind but here's some clarifications:
  • isn't reduced plant growth = algae?
  • does using less light also mean fewer hours of photoperiod? which is also = algae?
  • limiting NO3, in terms of EI method of dosage, will mean limitation of KN03 dosage?
If it's not too much to ask, a daily dosage example for stressing these red plants will be very much appreciated. Right now I do daily dose of macro/micro, half the measurement for my tank as per EI guidelines. I really wanted to try "yanking" em' out.
Oh, and by the way, do Iron also improve the 'redness' of these plants?
Thanks again!
But less NO3 itself will not.:confused:
Iron is not a factor, as far as I know, in determining if red plants will be very red.
Just remember that it is the amount of light that ultimately determines how fast plants grow. And, to avoid problems, including algae, it is desirable to maintain at least a slight surplus of all of the nutrients at all times, so it is the light alone that fixes the rate of growth. Everything we do to an aquarium has more of a cushion before problems appear if we don't try for maximum growth rates. So, reducing light to less than "high" light intensity, gives us more freedom to play with the dosages of fertilizers, thus making it easier to restrict the availability of nitrates without causing problems.
775
Generally, when we discuss less light, we mean less intensity, not fewer hours per day.
NO3 limitation can run the risk of some species of algae, BGA and few others, but BGA is inducible via low chronic NO3.
So you walk an edge with limiting ranges, some will get away with it, and they tend to have less light intensity, more plant biomass, maybe more fish etc.
So the advice I'm giving is not the best for growth, it's the best for amplifying red color though. However, red intensity is a sign of stress in many aquatic plant species, not health, but folks do not care, they want red color.
