I'm thinking of design and where to put everything the pump is the NW Eheim so it is a good flow. So mist will be pumped into the reactor either Vertical or Horizontal if I can.
As I say they generally work vertical, but to be honest I normally would reverse the order, but with that much pump you might get away with horizontal and for all I know that might improve the eddy diffusion and I bet you could still split the output.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
