dutchy;88190 said:
No, nothing of those. The pH controller keeps CO2 at the same level, even if I trim etc. I had this as long as I can remember. When I had 30 of them, I saw 10, now I have a 100, I see 20. There is a paper about breeding cardinals that says they are photofobic. They do come out when the light decreases, but this is also the moment the CO2 level gets less. I'll try some things.
I think it is the fry and eggs that are more light sensitive...
I have very high light (200 mmoles) at midwater and the cardinals do not seem shy at all. I really think it may be c02 OR they are scared.
I remember years ago I had little 'dawn' tetra approx 20 and about 80 cards. Well, the dawn tetras bullied the cards whenever they came out, so they hid all the time. Took me awhile to catch them at it and then actually believe it. The cards were twice the size lol
So, maybe something else is bothering them that is not readily apparent?
I know you will hate me for this but here goes anyway... I think you should investigate a wet/dry sump setup. Simply for the better 02 rate and degassing overnight when c02 is off.
I had much the same issue as you with cardinals since I got serious about c02 over the last few years. I would look at Tom's school and think, he has high c02, why are his fish out all the time? I knew B4 I used c02 I saw my cardinals more often.
I think they may be affected by c02 more than they show or we think.
Just a thought. You know I have gone around the world and tried many filtration setups over the last several years, from wet/dry sump to closed canister loop, and now back again lol
That said, the wet/dry seems to give the best success for me and easiest maintenance using c02 or not.
