hi from another newb
Discussion in 'Are you new to aquatic plants? Start here' started by wearsbunnyslippers, Dec 21, 2007.
  1. wearsbunnyslippers
    wearsbunnyslippers Prolific Poster
    Apr 2, 2007
    35
    4:59 AM
    these are my new tank specs:
    Tank Specs
    bowfront
    Height 500mm 20"
    Length 980mm 39"
    Depth 400mm 16"
    196000 cc
    50 US Gallons
    Lighting
    3*30w 10000K overdriven
    The light bulbs are jebo and they are an odd size 89cm/35" so I will change those to something in the 6000-8000k range as soon as i can find some tubes that fit.
    90w*1.7/50=3wpg
    CO2
    sera CO2 fertilization system
    sera GmbH :: CO2 fertilization system II
    Filtration
    eheim professional
    Eheim GmbH & Co. KG | EHEIM professionel (GB)
    Substrate - not sure which to use, any red flags for the below mentioned products?
    sera floredepot substrate
    sera GmbH :: Substrate
    tetra completesubstrate
    Tetra Aquaristics Tropical Ornamental Fish Food Care Medication Aquariums Equipment
    prodac fondovivo
    prodac fertiplant
    http://www.prodacinternational.it/en...dex.php?link=9
    I am in south africa and most of the decent products are very hard to come by or very expensive to import so I hope the stuff I have available will be ok.
    I currently have a 20 gallon bow front with 40watts of lighting and no co2, which is happily growing algae, the crypts, anubia and cabomba do ok, not fanatastic, but ok, so I am hoping to be able to grow some more demanding plants in my new setup.
    Any comments or recommendations on the above?
  2. Carissa
    Carissa Guru Class Expert
    Jun 8, 2007
    678
    4:59 AM
    If you don't already, I would suggest getting or making a drop checker and 4KH solution for your co2 enriched tanks to determine your co2 levels, and fertilizing all your macros and micros in all tanks. This would enable you to grow more plants and help get rid of any algae issues.
    Also 10,000K bulbs are fine for plants, but most people prefer lights in a bit lower spectrum just for looks.
  3. wearsbunnyslippers
    Apr 2, 2007
    35
    4:59 AM
    hi carissa,
    i will be dosing ferts using the ei method using:
    kno3 - potassium nitrate - saltpeter
    k2so4 - potassium sulfate - potash of sulfur
    mgso4 - magnesium sulfate - epsom salts
    kh2po4 - potassium phosphate - salts of potassium
    iron chelate
    hope this is ok?
  4. Carissa
    Jun 8, 2007
    678
    4:59 AM
    Sure, that sounds great! Since you're dosing both potassium nitrate and potassium phosphate, you can probably go pretty lean on the potassium sulfate. Also if your GH is higher than 40ppm or 3 degrees you may not need to dose magnesium sulfate. If it is lower than that, to cover all possibilities it would be good to dose both the magnesium sulfate and calcium chloride or calcium sulfate to get both the magnesium and calcium for your plants.
  5. philfarm
    philfarm Junior Poster
    Oct 24, 2009
    7
    4:59 AM
    Ha ha Just found this thread and thought it would be interesting to let you guys know this guy(Raymond) has just won Tank of the month on APC.:)
    click here
