here is my new 25g set up
Patrice
Jan 6, 2006
159
i have been working on that set up for the last 6 weaks.
What do you think of that start? a nice background will be a must but I'me still not sure about the color. also, at tha back (left side) plants will have to grow to follow the same shape the rocks have.
here are some info about the tank:
CO2: 1bubble /sec. waiting for a ph drop checker
2X65W (10h/day)
substrat: flourite
PH: way to low (about 5.5). I tried to make it higher but did not succede yet
KH: 4 to 5
NO3 I add 5ppm every 2 days
PO4 I add 0.5 ppm every 2 days
Fe and trace: 0.25ppm every other days
Water change: 50% every week
No fish in this tank for the moment.
I had some green hair algae the last weaks and also there is a little spot with cyano but it does not get worst or beter.... it's just there. I dont freak with algae for the moment. once I'll have my ph set to 30ppm, I'll see what happen.
any idea of how I could make it nicer?
reiverix
270
Not bad, not bad at all. I'll just warn that you might have not given quite enough space to the stem plants-- in which case they might end up a bit cramped and hard to make into well developed bushes.
Patrice
Jan 6, 2006
159
yeah, I tried less substrat at the front. there is about 3/4 inches at the front and more at the back. plants behind the rock are planted in flower pot so they have more substrat than it apear.
