I've asked this over on APC but haven't gotten much feedback yet. Maybe better luck here...
I'm helping a friend set up a large custom built glass tank and have several questions that I could use some help on:
1. The tank will be built into a wall and will have two cannister filters running on it (Eheim 2180 Pro III and Eheim 2260). The inputs and outputs will be through the bottom of the tank so we need to order it with holes drilled in the bottom. The 2180 has three hoses of 16/22mm (inside/outside diameter), two to the filter and one for the return. The 2260 has two hoses, one of 16/22mm and one of 25/34mm. So how big should the holes be for the bulkheads?
2. How to connect the flexible Eheim hoses to the bulkheads? I assume I need some pvc pipe from the bulkheads but how do I connect the hoses to the pvc?
3. The Eheim 2180 has two hoses to bring water from the tank to the filter. Does it pose a problem if there is only one output from the tank that splits into two to connect to the two hoses (reduces the number of holes required from five to four...)?
As you can tell, I'm not an expert with bulkheads and drilled tanks!
