Help With Swagelok Low Flow Angle Valve With Vernier Handle
Discussion in 'CO2 Enrichment' started by Lazy999, Oct 7, 2018.
  1. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:52 AM
    Hi everyone, Need help here. When i close my new swagelok low flow angle valve, i notice bubbles still coming out.
    Its cant close the co2 flow completely. Any idea how to adjust it?
  2. zchauvin
    zchauvin Member
    Jul 8, 2018
    34
    12:52 PM
    Sure it isn’t leftover pressure in the line?
    Sent from my iPhone using Tapatalk Pro
  3. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:52 AM
    When i turn the vernier handle to completely close and wait for 20min, the bps is still 4 per sec. Never slow down at all.
  4. rajkm
    rajkm Article Editor
    Sep 16, 2015
    659
    208
    5:52 PM
    Swagelok calves don’t have full close. Forcing it to full close will damage the seat.
    If you are getting 4bps at lowest then your pressure is too high. Usually at lowest it should be less than 1 bps.
  5. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:52 AM
    I set at 30psi and i'm using the jbl proflora inline diffuser.
Tags:
