Greetings! I found this site a few months ago and have been lurking, this is my first post.
I bought myself a new tank for Christmas.
It's a 46 gallon bow front. The tank is 36" wide, and just under 21" tall. I have a Coralife fixture with two 96 watt compact fluorescent bulbs, 6700K. I plan on running one bulb 12 hours a day and maybe the other one for a couple hours in the middle of the day as a surge. Filter is a HOB Aquaclear 50. The substrate is Florabase, the lfs likes it... I planted it this morning with a bunch of large Amazon swords, anubias, wendts, microswords, some water sprite and other clippings from my established 10 gallon tank. It's not as thickly planted as the small tank (the jungle) but it's getting there.
I'm planning to do a planted Discus tank after it cycles. I'm assuming the cycle will go pretty fast because I added a bunch of filter gunk and clippings from my established 10 gallon tank. I also did a 1 gallon water change on the established tank and dumped the water into the new tank. My water is rain water from a cistern at the barn. It runs pretty low PH, low GH. In the winter, I'll buy RO/DI water from the lfs, I need it sitting around for the salt tank (10 gallon mixed reef) anyway.
The 10 gallon tank planted tank has been set up since last May, with some neons/cardinals, a red betta, a couple guppies. Substrate is gravel, and I dose Seachem ferts and Excel daily. No C/02. I add Equilibrium & baking soda when I do a weekly water change. It's been very successful, I'm hoping to match that success with the new tank.
And that's my question. I've never tried Florabase before and I don't know how to dose with it. I don't mind dosing Excel and the other Seachem ferts. Can I dose the same ferts and the same schedule as the small tank even with the different substrate?
I'd like to move to EI eventually, but frankly my head is spinning a bit with the chemical names. If someone could give me some pretty specific brand names for chemicals, I'll wander by the local home store.
Thanks!
--SueP
Thanks!
--SueP
