Help with Led lighting
Discussion in 'Lighting' started by aquabillpers, Jul 5, 2015.
  1. aquabillpers
    aquabillpers Lifetime Charter Member
    639
    6:23 AM
    I have been growing aquatic plants for more than 20 years with some success. By that I mean that the plants grow and reproduce, and I almost never have to purchase a replacement for a species that I'd already bought.. My tanks are low tech, soil substrate, no fertilization beside what the fish supply. My main tank is a 29 gallon long, 30 inches in length. It's been lit with 60 watts of T12 tubes. Everything was fine.
    But then the T12 fixrture died (through drowning) and I need to replace it. My question is, what should I buy to at least equal what I had with the T12s, while maintaining my low tech approach?
    Thanks,
    Bill
  2. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,470
    6:23 AM
    Bill - my only advice if you go with LEDs is to not go for the ultra bright stuff...and get a dimmer. The balance you seemed to have with the old lighting will quickly be lost with higher light.
  3. skardos
    skardos Guest
    12:23 AM
    I am not an expert by any stretch, but here is my 2 cents for what it's worth.
    I am using a BeamsWork $55 with a manual dimmer $22 on a 20gal long, that is a heavily planted hi-tech. This light is more than enough for the tank, I have it dimmed to about 75%. You could dim it down even further for your setup and if you ever wanted to switch it to hi-tech you would have the light for it.
    BeamsWork LED Pent 30" HI Lumen 6500K
    http://www.aquatraders.com/LED-Aquarium-Lighting-Beamswork-Pent-HI-Lumen-p/56365p.htm
    Manual dimmer TrueLumen Inline LED Dimmer for LED Aquarium Lights:
    http://www.petsolutions.com/C/Aquarium-Lighting-Accessories/I/TrueLumen-Inline-LED-Dimmer-for-LED-Aquarium-Lights.aspx
  4. aquabillpers
    639
    6:23 AM
    Pikez and Skardos,
    Thanks for your advice. It appears that I need to be careful lest I provide too much light for my low tech tank.
    It appears that the BeamsWork LED fixture with the manual dimmer would work fine in my environment. Skardos, I assume that I would attach the dimmer to the fixture, then the fixture/dimmer to the timer, and the timer to the power source. Is this correct? It seems too easy.
    Thanks again,
    Bill
  5. skardos
    skardos Guest
    12:23 AM
    Plug the dimmer inline between the power transformer and the LED light. The BeamsWork light has a connector between the transformer and the light, the dimmer has a female and male end, very simple just plugin between the two. The surrounding housing of one of the ends is a little snug but connects just fine with a little effort. Since it is a manual dimmer once it is set the light will stay at that level until you adjust the knob up or down. Then just plug the power cord for the transformer into the timer. Very easy.
  6. aquabillpers
    639
    6:23 AM
    OK, thanks! I'll order them tonight. Let the algae war begin!
    Bill
  7. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    6:23 AM
    eBay has these dimmers much cheaper, <$4.
