Help With Fluvial 2.0 Lighting On 55 Breeder Aquarium
#1 Plant Boy
Aug 22, 2018
12
Washington State
I have a 55 gallon breeder aquarium and using a 48 inch fluvial 2.0 over it. The light is inside of the hood and is fixed in the center flat to the underside. Inside of the hood has white waterproof sealer. The hood sits level on top of the aquarium. Also there are glass covers on the aquarium. Both of which are clean
I measured with a apogee par' meter what the par was in the aquarium. I placed the par meter on the left side right in the middle and got a par' reading of 67. The I place it on the right side in the middle and got a par reading of 43. I also flipped the light around and still got the exact same readings. It is puzzling as to why I got such a lower reading on the right side than the left. The spiderwood wasn't on the right side when I took the par reading.
Any help is appreciated
rajkm
Article Editor
Article Editor
Sep 16, 2015
677
218
43
Hillsboro, OR
Take the wood out and try. I suspect it’s lack of reflective light.
jeffkrol
Jan 11, 2018
64
WI
Prob. a design defect ..sort of.. Bet it's on the other "side" of the power supply.
Thin copper traces can drop voltage over longer runs..
Interesting nobody's reported this before though..
