Help! Plant Id
I can't tell from the pics real well, but the hair grass itself is not doing that well. It seems to be melting and not growing..........esp pic 1
Could that be moss in there? For sure is not riccia........
What kind of tank, lights, substrate, filters, etc do you have?
Are you using c02?
crystalview
Sep 6, 2008
177
66
between Sac and Reno
Is the tank cycled?
Do you have fish in the tank or just CRS's?
How long has the tank been running?
Can we see a picture of the whole tank
Maybe if you back your camera up we might be able to see the plants better. I still have a lot of trouble taking pictures also.
Are you using Excel or ferts?
Sorry for all the questions but we need a little back ground. So many things effect a tank.
airriick
May 29, 2009
This is a 7.5 gal tank, with eheim eco cannister filter + amazionia II.
No I'm not using any Co2, the tank has been cycled over 3 weeks.
Only CRS and blue pearls.
I don't use any plant products, only things for shrimps.
I have two 10watt floursent bulbs. I was thinking about getting a T5 Hagen going across two tanks? :D
Stuff that add bacteria etc.
crystalview
Sep 6, 2008
177
66
Thanks for the info. Can you get some more pics?
You are right a bigger light would be nice for the plants it is real low Low now. Are you going to do el natural or something in between?
airriick
May 29, 2009
x.X el natural meaning.. adding no plant substances or co2?
Yes,
I was thinking about trying SeaChem flourish, or excel.
But I worry they harm shrimps since it's not a heavily planted tank..
crystalview
Sep 6, 2008
177
66
You can try to go without Excel but you may end up with algae. Which I think some shrimp like some kinds. Plants out compete the algae so the more the better. Flourish is good I use dry ferts because they are about 10x cheaper.
crystalview
Sep 6, 2008
177
66
The seachem Flourish would help with your micros do you plan on using macro's? Excel will also work on with your CRS. I might try a half dose of each since you have so few plants. Its hard to tell what would be best dose. If you do the weekly WC's either dose will work. I used less because my light was also low.
Dry Macro's are listed here: http://www.barrreport.com/estimative-index/2819-ei-light-those-less-techy-folks.html
Did you get an answer to plant ID since that is the title of the post?
