Help needed starogyne Repens browning & white patches in 2 weeks
Discussion in 'General Plant Topics' started by CHANDWE2, Mar 26, 2016.
  1. CHANDWE2
    CHANDWE2 Junior Poster
    Mar 26, 2016
    10
    3:12 AM
    It's been 2 weeks in my new 300 liters 120cm planted setup. Running 2 Eheim 2215 filters. Water temperature 25 degrees. Have been doing water changes 40-50% once every 3 days. Ph around 6.5, pressurized co2 around 30ppm. Fully carpet mainly glosso, some starogyne Repens, ananthera renki, ammania sp bonsai. I have 2 Kessil with lighting at 6 hours a day with ramp up of 1 hour to 85% intensity. Started dosing last week with seachem flourish and seachem potassium.
    Everything was fine until couple of days back. Glosso growing well, except few growing vertical, but the main issue is with starogyne Repens, they were really growing nicely all of a sudden could see few of them turning white on leaves, color darkening and almost seem like dying have no clue why this is so. Need help from experienced people
    The substrate is ADA Amazonia
    Also ammania sp bonsai died in few days of starting the setup may be poor stock or not sure.pl help
    #1 CHANDWE2, Mar 26, 2016
  2. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,465
    3:12 AM
    Many plants suffer in ADA soils during the first month or so. (But the hardy ones are really happy!) Likely the ammonia.
    Get past the first 4-6 weeks and things will improve. Until then, it is hard to pinpoint what the problem may be. Back off a little on traces. At this point, you mostly need tiny bits of potassium.
  3. CHANDWE2
    Mar 26, 2016
    10
    3:12 AM
    Hi pikes thanks for your reply Here is link to pictures the situation is getting little bad there are more Repens melting all the ones next to where the original Repens started. Attached are few pics
    [​IMG]
    [​IMG]
    [​IMG]
  4. Pikez
    May 12, 2013
    1,962
    1,465
    3:12 AM
    Looks bad. But you need to wait 3-4 more weeks for the soil to settle. In the meantime, do lots of water changes and dose just potassium and reduce the light intensity a little. You can begin adding fish in one or two weeks too.
  5. CHANDWE2
    Mar 26, 2016
    10
    3:12 AM
    Thank you pikez for your advice. Will keep posted the developments I already do 50% water changes once every 3 days due to say I increase the %level for every change or change the frequency to let's say once every 2 days instead of 3 days?
  6. CHANDWE2
    Mar 26, 2016
    10
    3:12 AM
    When I'm back from work this evening found All my Repens melted also alternenthera started melting did a 60% water change today checked ammonia levels prior to water change was at 0.25ppm. Ph 6.4, kh 3. Co2 30ppm. Not sure what is going wrong..
  7. skija
    skija Lifetime Members
    Nov 16, 2015
    352
    83
    3:12 AM
    Hi , any updates about stauro ? did you manage to fix the problem ?
  8. CHANDWE2
    Mar 26, 2016
    10
    3:12 AM
    Hi skija yes kept regular water changes and dosing rhythm lost all Repens (completely melted) and now slowly they have comeback again. Not sure the reason for melting. During the period I potted another Bunche of starogyne and they grew very well and once last couple of days they started melting. In my view the plants are probable adjusting. Initially they'd flourish and all off a sdden he melt and slowly comeback
